Item: R33 Manual Turbo, Factory Grey
Condition: Check pictures for everything
Price: If its not listed just ask and I will update with a price.
CHEAPER FOR SOME PARTS IF YOU WANT TO REMOVE THEM.
SOLD ITEMS/Smashed:
Engine
Engine loom
Gearbox
Front brakes
Front Passengers Light
Front Passengers Guard
Bonnet
front subframe- $150
steering rack- $100
Standard Suspension - $250
rear subframe + diff - $350
front seats- $100, Drivers has some wear marks
rear seat- $50
Complete Manual Conversion - $600
Tailshaft,
Clutch pedal
Brake Pedal
Gearbox Crossmember
Manual Dashcluster
Anything else you think you might need
Doors - $400 Complete for the pair
Boot + T wing- $250
seat belts- $150 the lot
fuel tank-$50
brake master cylinder/booster-100
Front Swaybar- $50
Catback exhaust - $350
Standard Wheels - $200, tyres are JUST legal
tail lights-100 for pair
speedo cluster -150
Any more parts you need just ask,
Edited by JiN_MaN
https://www.sau.com.au/forums/topic/295679-wrecking-r33/
  • Replies 54
hey mate, got any photos of the windscreen washer bottle?
also do you have the ashtray?
From memory the washer bottle is fine, but I cant remember is its got sold already or not.
Yep have the ash tray.
Take them both for $50 or if I dont have the washer bottle take the ash tray for $15
https://www.sau.com.au/forums/topic/295679-wrecking-r33/#findComment-4929252
cool man, where abouts are you located?
im after a clean washer bottle in good nick - got any photos?
Car is not stored at my house so sorry no photos. Located just off anzac highway
https://www.sau.com.au/forums/topic/295679-wrecking-r33/#findComment-4929301
Is that the washer bottle or the radiator overflow in the pictures on the drivers side next to the fuse box?
thats the rad overflow bottle. washer bottle sits in front of that with 2 pumps in it and a yellow cap
https://www.sau.com.au/forums/topic/295679-wrecking-r33/#findComment-4929331
hey mate have u still got the stock steering wheel??
if so what condition is it in and how much if so??
Sure do mate, $130
From memory its in fairly good condition, there are 2 pics of it, check them out as best you can.
https://www.sau.com.au/forums/topic/295679-wrecking-r33/#findComment-4929403
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
