i think anything that is top-feed will work. assuming they are larger than the factory size. im not sure that size is quoted in the manual, but its at home if youd like me to check?
try something from a RB26, but to be honest i have no idea what sort of flow capacity they are rated at.
maybe even VQ35DE upgraded injectors will be enough
Im looking at 600cc at least I recon, to allow further mods and E85 without getting near over-driving. I want to avoid running high pressure too. Is there one brand that stands out, especially with ethanol?
SR20? they are side feed, im 99% sure we have top feed.
except FWD SR20s, i think they are top feed.
nismo make 550cc and 700cc injectors. they may have a part that fits!
hmm... May have to change what I said. Dyslexia must have kicked in when putting the part# in Parts Master.
VQ25det injector part #16600-AA500
You are correct iain... no SR20.
Used in the following;
M35 - VQ25det (obviously)
R34 - RB25det
Y61 - TB48de
F50 - VQ30det
Apologies guys.
  • 11 months later...
I need to upgrade my injectors as they are running flat out. Any idea which injectors I need to look at that fit? I bought a tomei pump today, just need bigger squirters.
http://cgi.ebay.com/ebaymotors/350z-G35-GT...sQ5fAccessories
these actually plug and play? or will i need a spacer?
HELP
mine are at 94% lol :(
There are also
http://cgi.ebay.com/ebaymotors/DROP-IN-550...sQ5fAccessories
which are no name but guaranteed to just drop in.
ideas please
You are only maxing the flow due to running rich, my advice is to get an Emanage install to lean out the mixture and see how you go. The stock injectors should be good to around 200awkw and I dont think you are there yet.
If you decide you need new injectors, a Walbro or preferably a Nismo/Tomei pump is required also. I would suggest 550cc minimum as stock is 370cc, the second set are drop in with no plug changes.
so you reckon the second set is better?
is Walbro plug n play or will i need a spacer.
yeh i will do the emanage eventually. jus wanna do everything first like you said instead of back n forth ending up with $2000+ in tunes.
then BANG
You cant install the injectors until you have the Emanage in or it will foul the plugs just starting it.
Second set will fit, I have no idea on the quality.
where did my black hole statement go lol.
theres a couple of 350z nismo pumps on ebayfor about $100 does this seem right?
plus $500.00 for plugs
plus $1500 for emanage install tune.
someone kill me.
Emanage first, you only have to upgrade the pump/injectors if the AFR's are leaning, the tuner will advise that.
Emanage : $650 second hand
Install/Tune: $650
hmm with the loom? or do i need to make one any way..
You will need the universal loom, mine came with one, didnt it Cam. :)
lol yeh i meant injectors lol. having a blonde moment. execpt im a Curry :(
yeh theres a emanage n loom for total $550 shipped to melb.. i reckon drive carefully for a little while n check what the prices are like in december. hopefully we still have the same exchange rate lol
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
