I have been having a bit of trouble with my R32 GTST. I found that it was the AFM that was faulty and have since replaced it with a mates AFM, he now wants it back and i am having trouble locating another one exactly the same.
There is a green sticker on it that says
22680 02U00 A36-000-J60 on the top line
there is another number on the second line (in the middle of the sticker) but it has been half scratched off and i can't get the entire number, looks like 2027B
I have found an AFM with the same numbers on the top line (22680 02U00 A36-000-J60) but the number on the second line is different it is 7Y03B. Do i have to get exactly the same numbers?? I brought an AFM that i was told was suitable but when it turned up in the mail, the wiring loom had 5 prongs and mine only has 4 and the loom fitment was very tight, you almost had to force it to go on and it had no sticker or markings on it so i think that it was a fake, because it made the car splutter and break down.
The AFM i have on it at the momnet has a green sticker on it and has 4 prongs inside of it. Can anyone tell me what car this is off so that i might be able to source another one?? All the AFM's i have found with green stickers have 5 prongs. Is there a difference??
Does anyone have a working AFM the same that i can buy off them??
https://www.sau.com.au/forums/topic/295955-r32-afm-problem/
it sounds like a standard afm mate. if so ive had a few different 2nd hand ones on and numbers didn match and it worked fine. im pretty sure numbers are just serial and model numbers.
if you have an orange sticker than you have a z32 afm
https://www.sau.com.au/forums/topic/295955-r32-afm-problem/#findComment-4932285
Thanks for that mate, i was pretty sure about the numbers not needing to match, but was still a bit ify. Was yours on an R32? The air flow meter that i have on there at the moment is off an R31 Rb20, same motor as mine but i thought the different numbers might have meant something.
Nar it's definately not a Z32, would have been nice but it's a green sticker not orange.
https://www.sau.com.au/forums/topic/295955-r32-afm-problem/#findComment-4932712
yeh mines on a r32 with the r32 motor.
i now have a z32 as im upping the KW and the standard is to restrictive for my needs
Yeah i was thinking about getting a Z32 but i don't really need to because i haven't done many mods yet, just need a standard one for now.
Thanks for your assistance.
https://www.sau.com.au/forums/topic/295955-r32-afm-problem/#findComment-4937274
Hey I sent you a PM. I have a standard for sale if you would like it.
Hi,
Sorry mate, I have been trying to reply for days but because i'm only new on here i have to have 10 posts before i can reply.
Can you email me directly at [email protected] and let me know what the AFM is from and what sticker it has on it. Can you send me pics??
Thanks
https://www.sau.com.au/forums/topic/295955-r32-afm-problem/#findComment-4946483
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
