Is spectators allow? If so how much is gate entry ticket? Anyone know a decent hotel near by?
Thanks
go to superlap.com.au and the prices are there. If you order them online before the 13th you get a discount on entry.
no idea on hotels around there.
  • Replies 1.4k
Posted Images
its easy solved just run less front torque. the rear diffs are pretty much indestructable (only about 5% smaller than ford 9") and the driveshafts are OK but casn be upgraded.
the problem is....the more fwd, the quicker they go....so in an event like this they have to run 50/50 and hope for the best.
plenty of options for driveshafts, just jap even have billet stuff on the shelf. its the front diff that is the big issue.
where is lofty....how are you guys going with front diffs....you guys have by far the most experience with trying to put big power thru the front in circuit use.
bingo! duncan has hit it.. like you say it's easy fixed by less front drive and kinder shaft angles but then you'd end up with a standard height GTR with lots of oversteer and nice and slow...
like lofty obviously knows too basically the more front drive you can dial in the faster you go. downside is cvs breaking and if you beef them up then expect to bust a front diff or two out of the case (marks done that before but not in the 34). and with the front diff being housed in the sump assembly it's not something you can easily strengthen. maybe a full custom CNC billet sump would do it but fark I can't imagine the complexity of machining and the cost. my god man the cost!
everyone has been there and done it. garage saurus run their famous orange time attack GTR in full time 50/50. wont tell me how they get diffs to last but I imagine they limit front drive under braking too like dave explained.
as benno says mark has it well sussed with a similar system. this particular failure could be down to anything.
I hear the Panspeed RX7 is in a container and on its way, after receiving a nice freshen up, including a new Hollinger (replacing the Hewland) :happy:
More;
http://www.superlap.com.au/2009/?p=2948
Edited by Marlin
Me too mate, great things to drive :P
We're on the hunt for somewhere to test Hollywood's 32 after it's rebuild and new Hollinger in a couple of weeks. Lakeside or Morgan Park most likely. I'll make a point of checking the brakes too. :happy:
go the RWDs! The RX7s are carrying my hopes! Will be intersting to see how the NSX goes too. but the 900-1000bhp falcon I can't imagine being very competitive. Would have been better off keeping the V8 donk and spend as much time as possible tuning the car on those tyres at Eastern Creek I reckon, rather then building and fitting a kick ass I6 turbo motor.
And it would have been nice to have a NA V8 in Pro class.
pan speed RX7 is turbo, not NA 20B.
the pan speed car is one of my favourites. some pics I took of it at a Tsukuba hyper rev event. they are nice guys too.
I love the interior!
one nasty rear end!
I reckon the pan speed RX7 will be in the top 5 for sure. it's a very quick car and a good team behind it. It will be one of the quickest RWD that's for sure.
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
