  • Replies 1.4k
Posted Images
OK, i just can let this go.... so what is the story behind this pretty serious looking piece of kit?
Thanks to MaTBoY from photography section od SAU
Is it possibly the old Performance Metalcraft R33, that used to be yellow and have signage of som evineyard...just with a colour change??!! WOnder what happened to that car, it an twin 2835s or something and had plenty of kit
its a custom built RB32 from signature performance in Ipswich, Mick built it and drives it and has had it for the 3 or 4 years i have known him. Noel knows more about power figues and the like but it is very impressive. He had a lot of trouble getting the power down
Not sure what boost/power he was running at superlap but it has made 650rwhp on 21psi but around QR he only runs alot less boost due to wheelspin (which I believe is around 400-450rwhp).
I'll tell him about this thread this afternoon as he's tuning my car atm.
Its a work in progress. Mik had this car running some quite handy times at time attack.
An 11th hour decision to upgrade for super lap saw about 2 months of the most intense upgrades you could imagine.
Home made carbon fibre doors bonnet etc, Dog box, chromolloy cage, weight reduction and so much more.
Unfortunately time was against them and the car lacked development time to get the handling side properly sorted.
It augers well for next year however with all the hardware in place and a superlap visit under the belt I think you can expect much bigger and better things from this team next year.
anyone notice all the steam inside the r34 in the photo on the last page! hahaha
and water coming out the sill
Have a look just ahead of the right rear wheel in this photo ...
http://sphotos.ak.fbcdn.net/hphotos-ak-snc...7_4491309_n.jpg
- The Tuners Group
Edited by TheTunersGroup
Vid for those interested.....yes it is a Civic :ermm:
Fastest NA Open
Fastest FWD Open and Outright
8th Outright Open
Time 1.40.94
http://www.youtube.com/watch?v=0dnQW9MT-no
It was quick boz but i never thought I would hate the sound I hated worse than a drag rotor until i heard that f**ken noisy pos. :)
hey guys.... ive been up all night tossing and turning and thinking about next years superlap.. and my car....
why are there so many rules for Open... but Pro is invite only??
i want to move my engine back 15cm and section out the firewall... but this is not allowed in Open as the factory firewall must remain?? is that right??
but i cannot enter into Pro on my own accord as its invite only and spots are limited... is that right??
what can i do?? who can i talk to??
do i just do it and run some quick times at track days and hope for an invite??
pro just says no tube frame chassis or tube frame extensions on the chassis.... doesnt say
moving the engines around is allowed in japanese time attack..
i dont want a sports sedan category either... 15cm is hardly making it a sports sedan.. the original dash and everything will remain.. the firewall will just be sectioned back to the windscreen level..
if the original firewall must remain does that mean i cant section out bits to allow a pedal box to be mounted as far forward as possible??
    • This is for an RB20DET. Sorry for not including that.
    • Welp, this is where my compression lands after my rebuild. Thoughts? I have ~6 hours on the motor.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
