R32 Pwr Radiator 50mm Dual Pass With Oil Cooler
  • Replies 89
Posted Images
How long do we have to get into this GB. How many spots are left?
Also what kind of oil temps can we expect with this? Should you also run an external air to air exchanger or is this one good enough? My car gets a lot of use as a track car and I don't want to worry about oil temps or water temps.
you would expect you oil temps to stay teh same as your water temp
people in aus using on of these typically see just under 90 degrees water temp on a 36 degree day at the track
pete
they make a twin pass for a r33 gts
are the gtr one the same
??????????? dont know???????? there web site lists different part numbers.
I was looking at the web site and was thinking more along the lines of the 42mm (PWR2272) or the 50mm ( PWR0117), and just run the std rad cap and no internal oil cooler.
so do they have a power steering cooler and oil cooler, or just a p/s cooler? people i've spoken to down here have said they do a good job of cooling the oil, but also do a good job of heating the coolent up
I take it this will come with a spot for a over flow bottle hose?
Whats the best way to control the thermo fan? using a thermo switch like pwr sell ? http://www.pwr.com.au/#/view=products/s=as/
I run a pfc so i dont think it will control it.
Will there be a spot on the radiator to screw the switch in ? according to pwr they turn the fan on at 90 and off at 85.
As soon as i hear back from fatz ill deposit the money.
Some advice on this would be good.
Thanks
Tim.
depends how you run it
i run a thermo on the heater line that just turns on when required
other run the fan full time
its really up to you prefered way
but there are bungs so you can plum several things in
ill put up a diagram this week that show you what we are getting
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
