I decided to give my wheels a clean but i wasn't all that successful, attached is a before and after shot... now as you can see the brake dust has made a permanent home in the corner there (one of many corners actually) and so I'm looking for suggestions on ways to clean it, anything other than painting over it :)
Let this be a lesson for the lazy lol
degreaser and a microfibre towel, if that fails you could also employ a toothbrush.
i've done my rb25 and 4age motors this way and the 4a had never been cleaned
1. buy some alu-brite or aluminium acid..
2. hose wheels
3. spray it on with a squirty bottle
4. give it a bit of a scrub with a softish brush
5. hose off
6. pick your jaw up off the ground in amazement
ive done this on naked rims and painted rims, ive done it to some 20 year old volks that had never been cleaned, and they looked like new... and aslong as you get full coverage and dont let it dry (keep the wheel wet at all times) its safe as witches hats.. washing up gloves are recomended.. sunnys or glasses wouldnt go astray.. and try not to breathe it in too much.
cheers
Linton
tried degreaser, it didn't do anything lol and it's going to be difficult to rub and scrub cut and polish in the corner there :)
this stuff is baked on hard! i tried to scratch it and you can see my attempts in the middle of the baked on crap.
thanks for the other suggestions i'll give them a try and see how it goes ;)
I ended up giving jif a go today and it works (thanks to Dale you know who you are)! And as somebody else said would happen, I soon grew tired of scrubbing and scrubbing and decided to just live with it lol
I'll end up sand blasting and powder coating them anyways so it'll be perfect then :bunny:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
