Sau-vic Show'n'shine - Pics/discussion/results
chad your car looks freaking PHAT
Daniel im in love with your GTT.
location and set up looked great guys. sucks i missed out. oh well next year.
so who took home what trophies/awards?
  • Replies 99
Ash if you can get that place again next year!
should be able to judging by how well behaved you guys were, im gonna try so hard this year to get my Stagea up to wow factor!
Realistically we've given the powers that be no reason to say no to us going there next year.
So im 99% confident we'll be there next year :)
Looks like it was a good event. Good job to those taking the photos.
Shame i dont live in the area and am in the middle of a busy patch. Hopefully i can work towards being there next year.
Luke
It's not the council, its just common sense more than anything else. Its a public liability/protection issue.
We can't have cars coming/going in/out all day long.
1. It would be impossible to position cars
2. It would mean someone 'manning' the gate for the whole 6 hrs (boring/unfair to expect)
3. Given there must have been easily 500-700+ people of the public passing through there over the 6hrs... too much chance of something occuring
Great venue and the concerns regarding having the gates open all the time don't make sense.
But could we attempt to negotiate a later time?
I mean if it was 10-11AM or 11-12PM entry then that would be soooo much easier :)
412kw, run in tune... look for perhaps a ~450kw final result...... utterly mental :)
I don't think I grabbed a pic of the dyno tune, it wasn't a super-late response curve, it looked like it had a lot of power throughout the entire curve which is very impressive at those power levels.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
