  • Replies 44
Okay so far I have:
Luke_ENR34
Damo_R34
Aberax (subject to getting the day off)
Craig_R33 (maybe)
Anyone else? I'm bringing a carton of beer, and we might throw a few snags on the bbq ... all I need is your assistance to remove a box, then lift the manual into place ... 2-3 minutes work all up for beer and snags. :)
Come get some niggas! :D
Also ...
Just chasing down a few small items for the gearbox swap. Would anyone happen to have bolts for the pressure plate to flywheel ... and bolts for the gearbox to engine block (I hear the autos are different)?
Also, I'm assuming the tailshaft is the same length for auto and manual?
:D
Also ...
:D
the tailshafts on my datto conversions where of different yokes and shafts , so doubt they are the same
don't forget the little wire that tells the engine its ok to start cause the car is in park, its on the automatics , not stickshifts. most cases you can just plug the two ends together and wire tie it out of the way. if you dont the car wont turn over at all. neutral safety switch and the VSS sensor will prob be different on the auto car as well. lots to think about .... good luck mate
Thanks Troy :D Already got the complete write up and reading thru it again this weekend to cover all bases. Going out after lunch to start looking into the pedal box swap and handbrake install to get ahead on the job before next weekend.
Also, anyone know of a good engineer/mechanic to face the flywheel for me? And neither my clutch kit nor the gearbox came with a thrust bearing collar (or 'throw out bearing collar') ... anyone got one lying around?
Well, I've now since discovered that the clutch master cylinder cannot be installed without removing the engine, due to the plenum being in the way ... so looks like I might have some change of plans and be pulling the motor out complete with box.
So ... guess I'll be needing that engine hoist. :(
I find that hard to believe a motor or major removal to get to it,, japan doesnt design cars that need motors pulled for a simply clutch master change out.
even a plenum shouldn't need removal to get to it. most only take half hour max to swap out ruby ?
Well anyone who tells you the 260 and the RS4 are the same body, and all Autech did was stick in an RB26DETT, is lying/wrong. There are lots of differences. The 260 has a 4cm recessed section for the clutch master with booster. I'm getting the firewall recessed section and trans tunnel section for the shift hole/handbrake mount cut out of Nigel's wreck so I can suss it out. Maybe even have an engineer fabricate it in.
Another option is to just go with a 33 clutch master (non-boosted), but then the clutch pedal I have prob won't work. Its the little things they don't tell you about.
:down:
They probably use the body of a manual RS4 and just stick a 26 in it. I really don't see the point of making them different though :P
Just use the one without the booster. 32GTR's have boosters but i don't have one on my car, not really needed.
:P
You need to do more researh roo. This has all be covered a long time ago..... Read up some more to make it as smooth as possible :)
You need to do more researh roo. This has all be covered a long time ago..... Read up some more to make it as smooth as possible :D
I've found four different sources (albeit all being different versions/instructions), and it was the last one when I found out about the "recess". Even some of the info I found suddenly was inaccessible online! So I could not refer back to it. The original source I have for Stageas specifically is now back online :P WTF? Anyway, I went around to Dan's to look at Nigel's old 260 and sure enough, theres a recess. Might have to go the 33 master for now, just to get the job done ... but not too sure about how it will mate up with the 260 clutch pedal box. I just want to avoid buying extra parts, when I've already got the 260 parts there. :)
They probably use the body of a manual RS4 and just stick a 26 in it. I really don't see the point of making them different though :)
Lex, or anyone else with a manual RS4, can someone confirm this ... does the manual RS4 have the recess? It'd be interesting just to know.
:P
You do realise you'll be going from a push type clutch to a pull
No ... pull to a push.
But its not happening this weekend now. I cannot get some of the parts I need at such short notice ... parts that should have come by today have not, and I need to reschedule this for next weekend. Boo hiss!
Plan for next weekend. I'll let you guys know when I can confirm that.
:laugh:
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
