that and the bang bang puter, had to of upset the bearings
no i dont think knock was only ever 30 odd at bang bang, it was definitely already damaged before then
What type/brands of oil are getting ditched at 5000Kms?
i used to use Nulon fully synthetic a lot of people go for motul
its to do with synthetic oils passing by the rings and burning out your exhaust so when people say "oh it doenst burn oil' there mislead
i used to think the same 10000 is fine with synthetic but better safe than sorry
there is also a better reason but i cant explain it as good as i was told it :P but thats the gist of it
The reason I ask is, in the time I did 10,000 Kms I didn't need to top up the oil level at all. When I drained it, it was of course dirty coloured but certainly didn't look contaminated (ODO now reads 119K and I've never had it past 5.5-6K RPM).
A few people I spoke to suggested using Motul 8100 or 300V and changing at 10,000 simply because the oil is of a much higher specification than that used in 1995 when the engine fired up for the first time in the Nissan plant. I don't really know, this is my first turbo car!
keep in mind that 2 things stuff up oil....fuel & heat.....hence why regular changes in summer are handy not to mention tired motors need the oil dumped more often cause of fuel by-passing old rings
EDIT: and as Adrian said, peeps that boost more than others need to be more regular also (because of greater fuel by-pass under boost)
One that was daily driven to work, running stock boost should though..
My 20 only lived to about 105,000 before she died. Car was pretty much stock. Sometimes they just die young :P
I use fully synthetic and change it at 10,000, is there any particular reason why RB's need changing at 5000?
I thought it was for the turbo's. Turbos aren't supposed to like contaminated oil, wears out the bearings sooner.
And here's another I heard, that all these "race quality oils" we use dont have any detergents in them and cook mega easy because they are designed only to be used for say one trackday and then be thrown away...
We need oil Mythbusters :D
Chad, I guess mine fared a little better than yours then :P
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
