I know this is probably a long shot but does anyone know of any vids showing a GTR and a Hayabusi dragging. Just want to settle a bit of a dispute with a mate and would love to see it anyway.
If not a Hayabusa, then maybe other quick bikes R1 etc and of course with a win to the GTR.
Thanks!
https://www.sau.com.au/forums/topic/29759-gtr-vs-suzuki-hayabusi/
  • Replies 46
Thanks!
I have a video of a modified Supra dragging a stock Hayabusa. Would that help your dispute?
And a win to the GTR would prove what exactly? That you can tailor-build your own car for $80k+ that will beat a $15k motorcycle?
No, actually it would prove that a street registered car is capable of beating a $35000 bike or one of the quickest bikes around which is what he does not believe.
You could tailor build your own car for $80000 or you could just buy an R32 for $41000 with 850hp which is what I am test driving on Tuesday.
Of course a street registered car is capable of beating a Hayabusa.
It all depends on how much money you have to sink into the car. Oh, and just because it's street registered, doesn't mean it's street LEGAL, which it won't be.
Anyway, this is comparing a HEAVILY, HEAVILY modified car vs. Stock Hayabusa.
How about a modified street car vs. modified Hayabusa? Bye Bye Mr. Street Car :D
Saw a turbo-charged blue Hayabusa run at the creek once.  Man that thing flew...  Would hate to think what it would take in dollars on a street car to beat it.
Adrian
I would even venture to say it would be near impossible for a street car to beat it.
Stock busa does low-mid 10s... What would a worked (turbocharged, etc) busa run? mid-high 8s? low 9s?
How many 8 seconds cars do you know? Now ask yourself how many of them are true "street cars"? :)
But the thing is, with bikes that quick and powerful, there aren't that many riders out there that can launch them at their full potential, as they're scared of flipping the thing, or flying off the back.... and rightly so! I'd wet myself piloting a busa down the 1/4 mile, let alone a turbocharged one!!!! :D:)
Hayabusa at Final Battle was converted to 3-wheel, was turbo charged, and had NOS. Talked to the owner, and he said it's run a 5.5 1/4 mile assisted by NOS, and a 7.5 without NOS. And for some reason, it's registered as a car, because of the 3 wheels, and so he doesn't need to wear a helmet....insane
Martin Donnon once pondered in an Aussie mag (prob Hot4's) what it would be like to take the 1300cc motor from a Hayabusa and fit it to a Cappuccino.
Would LOVE a crack at one of those on a track! (Round a track not just straight along it though :D )
Adrian
I don't know what you've been smoking, but a Hayabusa does not cost anywhere near $35k. Unless you're talking about adding $20k worth of mods of course. But if you're talking about mods, see other people's posts above.
well my mate told me they were $33000 + on roads but anyway I got some vids....thanks guys.
Brand new they are just under $20k. Second hand you can get them for under $13k. $15k is about average. Have a look on Tradingpost if you don't believe me. For $35k a Hayabusa would be running 8's easily. I think there's a turbo kit for around $10k, plus you lengthen the swingarm to help stop it looping.
I'm not saying that one is better than the other, all I'm saying is by having a GTR that can beat a Hayabusa is only proving that you have more money to burn.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
