  • Replies 224
Awesome, will put the money in at lunch.
I was thinking I might do up an interactive/comparison graph for everybody's power/rpm graphs if they're interested.
Would it be possible to get a second print-out of everybody's graphs? Or I can just wait until afterwards and get people to take photos/scan their graphs and I'll input all the data.
I'm sure we could organise something with Alistair to get you an extra copy of the graphs :down:
I've just put together a demo of the dyno graphing/comparison thing. Still need to do some sort of interface for selecting cars/runs to compare, but hopefully this'll give everybody an idea of what I want to do with the data.
http://dyno.sauwa.net/demo/
Well I'll be bringing my camera, so there's no reason why I can put up a photo for each car.
Would be good if I can put up a pic of each of the dyno sheets because my graphs wont pick up on the finer details - i'm only putting in about 10 data points per graph and then using some crazy maths to interpolate the data up to ~40 points. So if I can put a photo of each person's graph that will let people see the detailed graph if needed.
I wonder if the Dyno Dynamics put of log files - if they do, I could plug the raw data directly into the graphs (which would be a lot quicker) and the digital graph would be even more accurate than the print-outs. Anybody know much about the dyno software?
We'll sort out something about getting you a printout of each dyno run. :blink:
Lol i believe i will be somewhere around where that orange line is... But with less boost :D
Heh, well the graph is my before tune and after tune results... except I've changed a bunch of stuff since then so I reckon I've undone all me good work.
Maybe I'll just take a picture of everybody's sheet - I can probably map out the data faster from photos. We'll see how it all goes. :banana:
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
