Sorry for the long delay... hows this?
http://franzonline.net/private/Perth/DSC03984.JPG
FranZ, absolutely top stuff there... you now officially have a fan in Japan!
Just one thing, this new one you posted is very similar to the one you posted a few weeks ago... don't get me wrong, they're superb pics, but a *daylight* pic of Perth in the exact same position but during the day around lunch time would show off Perth a bit better, as during the day it's easier to see just how much greenery is there (this is from a Japanese point of view!)
Sorry to ask, and I realize this isn't "Photos R Us"... but could you take a pic of Perth during the day?
If you can FranZ, when I come down there in April, I'll introduce to you the Japanese girls that I'm showing your work to.:)
Ta. I'll see what I can do; generally I work during the week and don't get a chance to get down there; weekends are normally motorsport or work orrientated! Gimme a few days and I'll see what I can do!
  • 4 weeks later...
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
