just failed a warrant ...too much movement in this bush...the guy at th testing station called it a tie rod but it just a link to the bush ...my question is what is the bush called so i can find a aftermarket one for it ...its at the back next to the shock connected to the link and the hicas lock bar...will link a picturepost-13324-1259364350_thumb.jpg
https://www.sau.com.au/forums/topic/298067-what-are-these-called/
na the guy is right its a tie rod not a bush
needs to be press fitted to the hub so hub will require removal to replace
looking forward to doing it to doing it to mine soon
from memory nissan only for these and not cheap
I couldnt find any aftermarket alternative
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
