  • Replies 216
Dudes,
I had a set of these on my old GTSt (now owned by MattyB). They have a 4 or 5 step change from blue to green and a 4 or 5 step brightness control too. They look awesome at night, and there is no reflection off the windscreen as Gus said the 'hood' of the dash covers them... They are not hard to install as they sit over the top of your existing guages.. Only problem is you either have to cut through the EL to get them over the needles or take the needles off which unless you are ultra careful will result in incorrect speed, revs, temp, fuel etc....
Definately worth the money...
Rice is nice sometimes... ha ha ha
*raises hand*
If we're looking at Jan/Feb then I'll be in for $200 for EL Kit also...I've wanted some for AGES!
fane,
We can do ours together, I've done some before!*
*Cannot gaurantee accurate speedo afterwards tho! (it's a bitch!)
$160 thats gotta be a bargain
and ina group buy might even be cheaper.
the ones i was trying to organise are going to be $200+
no chance in hell. so I canned it.
guess its down to autoworx and car quest and the spoiler shop
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
