  • Replies 216
memphis: can't get another one added on, sorry.
Everyone else: so far i've received deposits from everyone except fane.
I will wait till wednesday before I come after you with a knife ;)
dude obviously ur the stupid one. U didnt even read my question.
No. I'm not. and yes. I did. (*does the "no you're stupid" pants-down dance like a 2year old)
You asked....
Is it still to late for me to buy?? is it possible to get the white face to light up purple??
No, it's not possible to get these to light up purple.
k dude, but i didnt ask are they purple, i said is it possible to get purple???
Yes you did.
Okay, I'm done now.....let's drop it. :)
these will not come in purple. they are after all EL - which I think rely upon incandescence, so they will be "irredescent blue" or "irredescent green".
think glow in the dark stickers/stars.
if you want purple, the best bet would be purple condoms, or the ones described in the beginning of this thread - but these will light the numbers only.
I spose you could cut clear numbers out of purple plastic and have it purple during the day and glow purple numbers at night.
though why on earth you would want purple on the inside of your car is beyond me....it'd look like one of those bloody martian hot4s wrxs.
:vomit:
