I have come across a clear coat product called climat by accident , the GTR i just recently bought has been coated with clear coat , its imported from japan and is used over there to stop paint running as they have acid rain , its like a hard ass glass finish used all over the car , plastics , glass , paintwork it is re-applied every 2 years . A bit like RAIN X but for bodywork ,not just glass , i have been told this is an excellent product but does anybody else in Australia use or know where to buy a similar product locally !. Anyway heres a few pics of my GTR 32 !!!!!! :P
Does anyone else out there use a similar product that lasts 2 years ?????
Question is how long they last and how much. If coating the whole car cost a grand or 2 and last only 1 or 2years, I reckon not a lot will wanna do it considering you'll only need to polish it once a month or fornight. And a lot of us kinda enjoy washing the car.
I feel sorry for ya.
Have you seen what this shit looks like further down the track
big flaking of bits of clear coat crap, not a good look.
acid rain?? to lazy to look after there car more like it.
Oh shit. Yea that reminded me of my carbon wing. 100% true. Will get blemish/yellowish over time and flakey. Dont know if quality/brand of clearcoat plays a part in it or not but definitely shit on the carbon wing.
PS: not very fun spend hours sanding the clear away.
in japan you can see the door handles on newish cars paint runs down the body , majority have this product , it goes on just like wax . who knows what your on about!
Cmon Brandon grow up
You can get places that do paint protection on cars, similar to what they have from factory if that's what you are talking about.
yes but this product you apply yourself , by removing grease and debris from body first with a cleaner then apply climat to body , let dry to haze and buff off. the finish is like glass, but its all in the prep !
Sorry? What has that gotta do with growing up?
I just re-read your post before this and found you're actually using something like a polish thats work as sealant instead of what we're thinking of. I'm using the Mother range for clear-coat if that helps. Works wonder but you'll still need the wax every 6months or so and polish whenever you need it.
Thankyou ,i dont think the Japanese would put a nasty product that would peel off, mother is a good product it will not flake off and shit as you described ! Can mother go on plastics ?
Sorry i am a TOOL my bad
I'll check later when I'm home. But pretty sure they're safe. That bottle cost way more than the gaint bottle of autoglym polish I have.
Anyway you're missing the point. What we're going on about the clear-coat is we thought its a spray (like paint), or at least I am, which is used for sealing paintwork or making the surface smooth/shiny. These will peel after time and its like a layer of plastic which will become yellowish too.
I have come across a clear coat product called climat by accident , the GTR i just recently bought has been coated with clear coat , its imported from japan and is used over there to stop paint running as they have acid rain , its like a hard ass glass finish used all over the car , plastics , glass , paintwork it is re-applied every 2 years . A bit like RAIN X but for bodywork ,not just glass , i have been told this is an excellent product but does anybody else in Australia use or know where to buy a similar product locally !. Anyway heres a few pics of my GTR 32 !!!!!! :(
Where did you find Climat?
I use Auto Glym Car Polish... How does Climat compare to Auto Glym, does it give a better polish / shine result?
:O
I found climat in japan its used to protect cars from acid rain in the cities ,does auto glym coating eventually crack and go yellow , i have heard of it but never used it , climat is like a looking at a reflection in water (gay),i havent owned the car long enough to re-coat but makes me wonder if one day if climat will crack and discolour?????? will wait and see !
If that was a question, then no, I have polished my car last year with Auto Glym when I entered into the 2008 Auto Salon and still till today the paint has been fine.
I guess if you spend a lot of time on any car with polish, it can be like looking at your refection in the water... LOL!
You still dont get it do you? I said the clearcoat we thought you were referring to is a type of paint that is sprayed on. Not something like a polish. The yellowish and blemish I'm going on about is for the paint spray type of clearcoating.
Anyway this is the mother product I'm using. Its comparable to zymol's finish from memory (used to work for sparkles detailing and I find zymol's result is the best I've seen).
http://www.mothers.com/02_products/10116.html
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
