yeah bang for buck it's pretty good, ( be better on E85, diff go's bang ) not bad for a daily
2 points higher, if it was actually higher, would make it run a bee's dick richer, hardly worth plugging the laptop in but!
Or get a gearbox full of third........
2 points higher i would have thought be richer too....Alls i know is that fuel will not be going in my daily ever again....E85 on the other hand hmmmm....
  • Replies 46
Well the United site lists E85 being sold only at United Tapleys, hopefully they will bring it to Salisbury, then ill seriously consider it.
http://www.unitedpetroleum.com.au/distribu...5-locations.asp
Increasing by 2 points shouldn't make it run like a POS if it ran fine on BP 98 though......different story when decreasing by the same amount.
Apart from running slightly cleaner, the only issue by not tuning to the extra 2 points would be that you would not be taking advantage of the increased octane.
I stand to be corrected by the tuning gurus though. :D
I may be wrong but thought I read the V8 supercars switched to E85 and had a world of issues until they got the tune right. I don't think the RON value is the issue, maybe it's the way the fuel burns which requires the vehicle to be tuned accordingly. I've also heard you will use a third more fuel if tuned correctly thus burning the cost advantage. So ultimately the only advantage to E85 on a standard vehicle would be your conscience effort to support the environment.
^^ not entrily true
Less knock and more power even if it uses more fuel you still get more power
yes but on gasolene more power does not always mean you're burning more fuel. Your engine will burn more E85 per Kilowatt than gasolene no matter what the tune, so the cost advantage is moot.
And FWIW I don't think the v8's changed to E85 because they get more power out of it, I think it was enviironmentaly driven............pardon the pun :D
When peeps convert to E85, cost doesn't even come into it, neither does the environment...that's just a bit of cream on the cake.
They do it purely for higher state of tune that can be achieved and extra boost that can be had without the leaning and knocking that pump gas gives you at maximum AFR's and timing.....hence more power, with only injector and fuel component upgrades needed.
My 34 has been runnig on e85 for daily duties for over 9 months now, and there is no issues once tuning and injectors and better fuel pump gets addressed.
To run this fuel you have to add the supporting mods you cant just put it in and expect more power or reliable operation. I did it properly once and the car runs the same as on pump fuel sligtly smoother at idle.
And FWIW I don't think the v8's changed to E85 because they get more power out of it, I think it was enviironmentaly driven............pardon the pun ;)
Your wrong. My car would ony make 280awkw on 98premium, the day i changed to e85 the car jumped to 300kw with no tuning, and then up to 315awkw with a better tune. So yes e85 does make more power, you do burn slightly more of it, and at the end of the day dont give a hoot how much it costs, i was buying it from scotchers at 1.80 per litre but out at mallala the car is always on redline on every gear change without even the slightest misfire or anything.
that's a bit of a blanket statement, which part of my posts are wrong? To summise I've stated so far:
Yes you need to tune to suit E85
Yes you will get more power on E85
Yes you will use more fuel doing so
Yes the running costs will go up.
So what is so wrong with what I said when you just confirmed all of it.......... :rofl:
And let's not forget that I've stated all this in relation to the GP who drive street cars, not race tuned track cars.
And FWIW I don't think the v8's changed to E85 because they get more power out of it, I think it was enviironmentaly driven............pardon the pun :rofl:
This bit :P
then I'll make the blanket statement and say YOU are wrong. :rofl:
The press release:
E85 fuel supplier announced
Friday 10/10/2008 13:10
Author: Briar Gunther | Source: BigPond Sport - copyright
V8s at Phillip Island
CSR Ethanol was this morning named as the official fuel supplier of the V8 Supercar Championship Series for 2009 and beyond.
V8 Supercars Australia Chairman Tony Cochrane joined Ian Glasson, the Chief Executive Officer of CSR Sugar – an associated company of CSR Ethanol - at the Supercheap Auto Bathurst 1000 on Friday to make the announcement.
While this year V8 Supercars use a five per cent ethanol blended fuel, next year they will run the E85 fuel which is an 85 per cent ethanol and 15 per cent petroleum blended fuel.
The safety cars will also run on the E85 fuel, which is made from molasses (a byproduct of sugar cane).
“This is one (announcement) that I think we’re particularly proud of at V8 Supercars Australia,” Cochrane said.
“It’s not only a great day for our sport, it’s a great day for the environment, and a great day for renewable energy here in Australia.
“What we consider is one of our key roles in all of this quite frankly is to help educate over the next five years the Australian motoring public in particular.”
Glasson said E85 fuel will substantially lower the greenhouse footprint of motor racing.
“CSR Ethanol is delighted to be part of V8 Supercars to improve the environmental footprint of the sport and also to establish ethanol as a very credible fuel, not only in V8 Supercars but across the Australian motoring public,” he said.
“Every litre of E85 produces about half the greenhouse gas of traditional fuel.
“That’s a very significant improvement and not only is it sustainable but renewable.”
So not environment driven then !!!!!!!
http://envirofuel.com.au/2008/03/01/v8-sup...se-e85-in-2009/
Edited by mosoto
the teams mechanics dont give much away while looking for any advantage they can get, atm they are more interested in economy than power and since e85 can be run much leaner before shit melts thats the direction they are playing, IMO the teams who can afford to run leaner will win, triple 8 have the advantage here because they have lots $$$ and can push there engines further
V8SA's green theme doesnt seem as friendly if someone mentions performance
Your missing the point. A car wil get as much as a 40kw increase by switching to e85 over premium.
Im not fighting the fact that it is an enviro fuel. All im saying is the prformance benefits are quite large. So if you think tyres is what make horsepower in an engne than thats fine. Id rather beleive what my figures say than someones press release.
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
