34's are considered the pic of the stock dumps
thought the were stainless so rust is weird?
found alot of stuff on my R32 has like one stud one bolt etc.
sometimes when you go to bolt it up it makes sence sometimes less so
If the flange faces are square/flat checked with a steel rule etc.
and thats all ya got go with em I reckon
https://www.sau.com.au/forums/topic/298454-r34-gtr-dumps/#findComment-4964833
not sure if you plan to use o2 sensors if you do check my post here
http://www.skylinesaustralia.com/forums/O2...rs-t298491.html
reckon you will run into the same or similar problem as R34 o2 sensors are a larger thread and I suspect longer reach than R32
Flanges can be machined just extra cash involved if ya cant do it yaself or at least at mates rates
dont reckon it would be to pricey anyway
Edited by noone
https://www.sau.com.au/forums/topic/298454-r34-gtr-dumps/#findComment-4965222
If there are O2 sensors in there now then I plan to run them in the new dumps. I would not get mates rates and I'm sure as hewll not doing it myself. It's now a question of how much and more importantly who will do it correctly so the R32 sensors fit the thread and the depth.........Knew this would be a pain...
https://www.sau.com.au/forums/topic/298454-r34-gtr-dumps/#findComment-4965281
You're not talking about the old ones that may come in the dumps are you? o2s are a maintenance item, every 40,000ks or so.
Just take the dumps and the sensor to an exhaust shop. I had xforce dumps and they come with a hopeless adapter that if used wouldnt have put the sensor in the exhaust flow at all. Castle hill exhaust cut off the 33/34 mount and welded in the adapter in its place so that the 32 o2 sensor would be in the exhaust flow. $70. Or if your current o2s arent new just get new ones 33/34 ones like ali says. They're a different type (zirconia vs titania on the 32) but reportedly work fine.
https://www.sau.com.au/forums/topic/298454-r34-gtr-dumps/#findComment-4965371
I was, but I'm happy to be corrected
Well how far into the exhaust flow do they need to be? Anyone got a rough cost of the O2 sensors? 'Reportedly' worries me......Nothing is sure in the game of stuffing around with GTRs....
https://www.sau.com.au/forums/topic/298454-r34-gtr-dumps/#findComment-4965486
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
