Well I was asked quite a few months ago to put my EVO VII in my mates wedding next January, Saturday the 16th.
When I was asked it had my old 'grenades' on and looked pretty tough, when i sold the skyline the 'grenades' went with it.
Needless to say it is now sporting the stockies and i would just prefer that it had some tough aftermarket wheels.
So basically what i'm hoping is if there is someone out there who would kindly lend me there 34 GTR wheels or something similair around the 18x9" (offsets and widths must be same all round) for a couple of days.
They will see no more than 150kms of rd and the car will be getting driven by a 50yr old man.
Cheers in advance.
https://www.sau.com.au/forums/topic/298567-hoping-for-a-favour/
Thanks for the offers so far guys, cause of the evo's constant AWD i really need the same widths and offsets all round.
18x9" +30 would be perfect (34GTR rims, work xd9's, volk te37's etc.)
Cheers again.
also so long as the rolling diameter is the same width and offset doesn't matter
I thought that we'd been through this before, lol
Here see if you can find two sizes that have the SAME rolling diameter. i bet you can't, say $5.
http://www.1010tires.com/tiresizecalculator.asp
i got 4 work emotion XD9's, 18x10 +18 with 275's on them if u get stuck
^ +1, 255 is a huge stretch on a 8.5" inch wheel imo unless the tyre is a semi slick... i havent done any calculations, but i estimate the rolling diameter difference to be anything from 0.25% to 1.5%
only a bees dick not enough to worry attessa
moodles did you even read it 255 is no stretch on a 8.5" rim :D
Actually you are completely right, I only had 13hrs sleep over the past 3 days... I think what I meant to say was its alittle big for the rim, sidewall wouldnt be as strong as the one on the 9" rim which would give slight difference to overall diameter...
Bees dick does make a difference with ATTESSA, I had Potenza G3's 225/50/R16's all around on my 32 GTR stockies and tore up my fronts at the track (if anyone remembers the private track day, I even considered running that tyre in reverse rotation... for about 30 seconds), I had Kumho KU36's on to replace those front ones in the exact same profile while keeping my rear G3's (tyre place only had 1 pair, and I couldn't drive around with outright defectable front tyres). The rears still have about 50% tread left... but the tread difference alone is enough to make my ATTESSA put power to the front wheels 24/7 (even if its just alittle bit)
should be careful with the 33's ATESSA Steve because of the preload on the clutch packs. With a difference in sidewall height of 10mm (5mm top and bottom) produces a 3% difference in rolling circumference which is 3km/h at 100km/h (obviously). This will produce premature wear on the clutch packs (especially on 33 and 34's) which as you will know are very expensive to replace. You might not have problems for a number of years but when R32GTR's are 20 years old now and they don't have problems with their clutch packs if you have problems after say 5 years then it has been caused by something, and as for your split as you would know when your gauge says 0 it's already at 10%.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
