You may have some issues although nobody could tell me what the difference is between the ARX and RS suspension.
I suspect the BC coilovers I bought may have been for the ARX as the rears were nothing like what I needed, but I never checked, I just modified them.
A friend has just bought an ARX (GOLD LIKE YOURS) and has been speaking to Just Jap as I believe they are having some made that will be available quite soon.
I will try to get some more specific details for you.
Cheers
Andy
I was recently speaking to a guy selling BC coilovers on Ebay, runs his business out of New Zealand. Told him of the issues scotty had with them, he made enquiries to BC, apparrently, they have updated the NM35 kit (sept or so) to correct the issues. He was witing for updated parts for his kits at the time. So presumably, any kit ordered now, would be correct.
Hope this helps, Dale
Thanks guys I've been looking on eBay as well and seen the same things but this guy in new Zealand is not responding to my emails and waiting for an answer back for tenabe ones guess I ll
have to just wait and see what happens
thanks again guys
thanks again guys
Be careful which set if you buy for an ARX.
Yes Tanabe NF are adjustible... from -37mm to -78mm front and -38mm to -73mm rear WHEN FITTED TO AN RS, which means that on an ARX, you will be 77mm lower at the front from stock ride height when the Tanabe's are fully wound out!!
Maybe look for Bilstein or Nismo dampers and add a set of springs that are suitable for ARX.
Edited by iamhe77
do u think they will fit straight on without any mods
Do not know for sure.
I can't imagine that the setup would be any different, but you have to remember that the ARX is 40mm higher from factory than the RS/RX.
Can you trial fit?
They're not technically coil overs on the rear of an M35 as the springs are separate from the shocks. So only the front is true coil over and that's as per standard.
Cheers
Gary
I think most of us are aware of the old "coilover" chestnut.
Given your expertise in the industry, would you happen to have a suspension solution for the original question (also for the RS/RX owners)?
There's a few people (myself included) who would welcome a local solution rather than resorting to importing parts ourselves...
Cheers, Dale
Cheers, Dale
I second that motion local is easiest way
but I'm leaning towards resetting the springs any positive or negative thoughts on this way I've been td that u get the same ride comfort as factory what do u guys think
cheers Damon
I had a set of Bilsteins fitted to the ARX but kept the original springs for ride height (wanted to keep the stock look plus find the tailgate is fairly low already). This generally fixed the washy ride but it now crashes over the slightest depression in the road. I guess that the softish stock springs are not matched to the stiff Billsteins.
Currently waiting to get a set of ARX height Pedders springs made thorugh Ben at Northshore. Apparently 30% stiffer springs.
The stiffer springs should also help cornering - perhaps what it will finally need is an adjustable set of sway bars like Andy has done.
cheers Damon
the ride with the the Lowered Bilstein springs and sway bars is definatley firmer and can crash over some bumps but mind you with the stock setup the car was leaping over the road through the same pot holes. Also a big factor will be the tires you have on your car. the stiffness of the side wall is noticeable.
I guess for me the real test was from the seat of the pants of my wife. She thinks the ride is very good and has no problem with the stiffness of the set up and she is definable not into performance cars at all.
And best of all,, I love it. :)
On the topic of coilovers/suspension,
i have the tein kit on my car, it gets a little bouncy in the rear end still.. what do i do to fix this problem?
What kind of adjustment to they have? none? Height? Height & damper?
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
