  • Replies 115
hahaha i know your guessing but from that pic how can you see the axels that go through the engine sump :) really up high there is no difference from gts4 to gtst
he can put an attessa switch in instant rwd without dropping a shaft
I said that because R32 GTS4's came standard with ABS, and it doesnt have ABS. Yes it could have been removed, but for example Dans R32-R which has been de-ABS'd still has reminants in the bay..
But youre absolutely right, I cant see the axles through the sump :(
Come on Tangles, confirm what it is!
edit: it has staggered rims too........
The R32 sedans were offered with four-cylinder and inline-six engines, of which the basic was the CA18i, a normally aspirated 1.8l 4-cylinder with 91hp at 5200rpm (GXi). Next was the RB20DE, a 2.0 l normally aspirated inline-6 with 155hp, for the Click for a larger imageGTS. Top of the bunch was the turbo-charged RB20DET, with 215hp/6400rpm and 263Nm/3200rpm of torque, which worked in the GTS-t and GTS4 models. Later, the GTS25 also got the RB25DE, a normally aspirated 2.5l inline-6 with 180hp at 6400rpm and 231Nm at 4800rpm. 4-speed automatic and 5-speed manual transmissions were available. The automatic even came with a so-called “power”-mode, in which the box holds the lower gears until about 5000rpm, instead of the usual 3000, before shifting up a gear. For the first time in a Skyline, power was fed either to the rear via a viscous limited-slip-differential, or to all four wheels (GTS4). On the passive side, ventilated disc brakes all around with 4-piston calipers up front and 2-piston calipers in the rear kept this power in check; ABS was available optionally.
Source
rebuilt Rb30 gearbox
that wont last long. start shopping for a 25 box.
i knew someone was gonna bring up the whole higher RON thingy...but who cares, LPG is still homo lol
~60-70 cpl, 115 octane, how is it homo?
I don't rate LPG... Yes its higher ron whatevz but imo its wack as f**k. Epic converters needed if you want to run decent power, another tank install makes for a very messy setup. I'd only consider it if I had big $$ for alot of custom parts to hide all the condensors otherwise makes your bay a mess, and if it was a Drag only car. Tubbed, caged, 4link etc.
Congrats on the buy man, its going to be a ball of fun. Having a RB30 gearbox you would think its RWD? lol
That gearbox won't last long. They sturggle with stock RB30ET power. If its the MX7 (genuine turbo box) It'll last yyou some time but dont expect a MF5 to hold up long after a couple powerskids lol.
P!ss them wack rims off asap too :)
Edited by Weezy
i dont know what your talking about :) lies all lies
comes with spare GTR gearbox, so all is good
rwd, petrol, six&ahalf G, done deal, on early flight tomorrow to melb, home tomorrow night.
* happy pants
:P
dent to fix. got a longer seat rail on order already :D
already have my previous decent new 17's rims, a new seat I didnt like in the Stag, etc.
bit's to do, but gonna be good fun.
all in lieu of the bike - which I have used for like 400kms only.
so yeh a good deal to keep me happy.
The new direct port gas injection is a good piece of gear. All the new holdens and fords have to use the new system because of their ECU. The new systems give you the same fuel control as multi point fuel injecton and can make some really good numbers.
Brett for Graham West got around the 340rwkw mark with their XR6T with just a slight boost increase and LPG.
thread fail, need advice on r32 gtr and you go and get yourself a gts tangles tangles tangles
sorry
:P all I can "afford" seeing its in lieu of having a bike
already got attessa in the stag - now have GTR rb26dett & gearbox
might find its way in - ? :D
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
