Hey guys,
Wrecking a white manual R32 GTS-t. Lots of part available, can obtain photos of parts if required.
PM for availability and price.
Some prices and parts are as below.
Headlights (Projector) - 150 ea
Tailights - 100 ea
Indicators - 100 ea
Bonnet - 50 (grey, small dent in the front and a few scratches)
KYB standard shocks - 100 set (front and rear - only 10,000k's)
Standard springs - 50 set (front and rear)
K&N pod filter and adaptor (suit rb20) - 40
Front seats - 300
Back seats - 150
Front and rear brake calipers - 500
Cheers
Stephen
https://www.sau.com.au/forums/topic/299307-wrecking-r32-gts-t/
Post prices for ALL parts or this will be locked.
The rules are plain and simple, and there for a reason
Parts above are currently all that i have off the car ready to sell.
Will update thread with parts and prices as they become available.
Do you have stock turbo?
Hey guys,
Tailights - 100 ea
Indicators - 100 ea
Front seats - 300
Back seats - 150
Cheers
Stephen
PM me when u have avail - Back seat side trims and over trims dont know names but all the side arm rest n crap both sides if they in good non peeling nick ill grab em
PMs replied
Front bar - 80
Boot lid - 150
Standard shock/spring combo inc strut tops - 150 set
N1 style side skirts (white) - 300
Tailshaft - 150
Differential - 120
Prices are negotiable for right buyer!!!!
PMs replied
Front bar - 80
Boot lid - 150
Tailshaft - 150
Differential - 120
can i get ur number as i'm interested in a few parts and willing to come out and have a look?
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
