car was imported this year
series 2 r33 gtst
4sp Auto gearbox $500
a/c control $120
ABS brake master cylinder $100
ABS unit $100
Auto Diff $280
Auto gear stick surround $30
Auto tail shaft $150
b pillar covers (pair) $40
back bumper $150
boot seal $30
carpet $100
center light $20
Centre console $50
cluster surround $50
driver door with glass and motor $200
driver mirror $50
driver side door frame and seal $50
Driver Side Headlight $250
Driver Side Mirror With Glass $60
front map light $50
Hood Lining $50
indicator stalk $50
Instrument cluster (auto) $150
passanger door frame and seal $50
passanger side kick panel $50
Radiator support $200
rb25 throttle cable $30
rear corner windows (pair) $150
rear door trims (pair) $100
rear handles (pair) $50
Rear seats $100
rear sway bar $50
rear view mirror $30
rear window $150
S2 Dash surround with clock, hazard switch and demister switch $90
S2 dash with air bag and panel $400
s2 roof liner $100
scuff plates $30
seatbelts (full set) $150
Standard Rb25 BOV $30
Stock airbox $30
tail lights (pair) $300
washer stalk $50
White boot with holes for GTR wing $100
white fuel cap $20
white rear garnish $70
also have interior trim items!
prices are negotiable!
https://www.sau.com.au/forums/topic/299716-r33-series-2-parts/
  • Replies 46
Hi,
You got drivers side A pillar trim without holes or damage?
If so, PM me your price for it posted to 3199.
Cheers
Grant
Hi mate,
have u got front bar and reo? might be keen for just front bar, but may also need reo. depending if it will fit my S2 4dr.
please txt me on 0411 985 563 as i don't come on here often.
regards
Hi mate,
regards
txt'd
do u still have the airbox?
do u have the glovebox still aswell??
im in SA
sure do ,
box has a couple scratches on it and im not sure about the glovebox
more then welcome to come around n have a look
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
