heyas,
i need some help setting up an SAFC II in my mates 32gts4, i installed the safc and i know its wired in right, i have the throttle set diagonally upward right and set to 6cyl, i have hot-wire selected and this is where is gets confusing, i have the in out scale set to 2, so 2in 2out, then next menu is a cal. menu with the same Xin Xout which is set a the factory 1 at the moment, so cal. 1in 1out, i have read somewhere on here the scale should be set to 2in 4out, but when i tried this with his rb20 it ran like a cop with a HUGE misfire at 3k, which didnt allow the motor to rev past 3.5 or so....so my Q's are
wat should the scale be set to?
and
wat should the cal. be set to?
the car seems to run fine on 2in 2out so i am leaving it there until i can get somebody to give me straight facts which the motor is happy with.
the car has the following mods,
3" turbo back
FMIC kit
Pod filter wit mesh screens removed
13psi
and the SAFC II
cheers
wog
https://www.sau.com.au/forums/topic/299751-safc-ii-in-a-r32-rb20det/
i am running one in mine but somethin is wrong still tryn to work it out.. nothing comes up on the screen no more only the key pad lights up orange??? car didnt run. so i unplugged it do u no anything about it .. taking it to tuner next week to try get fixed then tuned again...
well i have wired a few in, not sure wat would cause the screen to not work and the pad to work, maybe the screen is fubared!
wats your location? if your in perth i could have a look at it for you, i think most people go powerFC which is why i have got limited responses in this thread, but once i find the proper settings ill post em up for others, people ask these sorta Q's!!
-wog
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
