Hi Everyone,
I've got two Takata 6 point race harnesses for sale, they are brand new and come with all required eyelet bolts. They are also still valid till the end of 2010 for any CAMS or other governing motorsport body regulated race events. I've just been notified by a mate on another forum just now that the regs. have changed and they are good for five years now so that means valid till 2015.
Price: $300 each
Postage: Australia wide at buyers expense
Cheers!
Craig
https://www.sau.com.au/forums/topic/299822-vic-takata-6-point-harness-x2/
Damn thats no good, they are indeed a fake, according to the link posted. Can you return them to whoever you purchased them off?
Check here for reference: http://www.nissansilvia.com/forums/index.p...howtopic=324958
Edited by JiN_MaN
as above, thorough comparison shows that urs looks to be a dodgey. on a brighter note, i can offer $50 jus so i can use it with my indoor gaming setup lol
Hi Guys,
Thanks for pointing this out to me, I had no idea and do not want to be a dodgy seller as such. I bought them a couple of years back now so there's no hope of a refund, I can't even remember who I bought them off now :)
That aside, they are still a very high quality harness and still in brand new condition. I've used them a couple of times the once I had them installed and had no issues what so ever with them, was held very tight into the seat while being quite comfortable having the wide straps.
Due to them not being genuine, aka "copies" I'm reducing the price to $200 each :)
Thanks,
Craig
  • 5 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
