yer i found a leak...
The bracket for the heat sheild makes the contact between the dump and turbo realy uneaven...
I have exhaust wrap over the dump. My question is can i go without the heatsheild? does it realy block that much heat? I can just mount the wires up a bit higher near the abs, will they melt or anything?
2. Is the wire/connection that goes in the top of the dump my knock sensor?
do you know a way of mounting the heat shield without using the bracket that goes between the dump and turbo... Cuz it doesnt do up any tighter and there is still a gap cuz its uneven.. I just put it togethor then without the shield and i was just going to put exhaust wrap over the connection and wires that come from the top of the dump... But if it makes a big difference i would like to put the shield back on....I dont know how to mount it tho.... + i polished it last night :D
If I read you correctly, you've stuck the heat shield bracket BETWEEN the turbo and the dump. Right?
It goes OUTSIDE the flange ie dump mounts up to turbo, and bracket sits on dump, then put bolts thru bracket and dump into turbo.
The wire / connection is the O2 sensor.
Nope. The knock sensors are on the inlet side of the block underneath the inlet manifold.
The sensor in the top of your dump pipe is the O2 sensor...
Can't help with the mounting sorry :D
GAWD IM A DUM SH1T!
haha.. i cant beleive i didnt do that..
thanks mate
in the attached image.. the green ones are the bolts that i have done up tight.. the 2 red ones i cant do up cuz there is no room to tighten them cus the spanner or whatever else i use hits the dump and cant be turned... how could i tighten these up? I cant feel any air or hear any leak from it...
ok image didnt upload... I have the four outside ones done.. The other 2 are impossible to get to.
I havent realy tested it out yet.. i have only gone to .4bar.. Should i turn boost down or anything like that first... i only have a bleed running .8 atm... this was before the pipe/cat was put on... Should i be listing to anything while i am testing it?
thanks
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
