So My Turbo Is No Good For Rb30DET? i only need to get a few more things togeather to finish the build, also quick question are RB20Det red top lifters the same as RB25DET ones? just a question. mayb i start a build thread.
That turbo will be OK, but it is not the best turbo [its not even in the top 10] for the job. Don't buy a cheap turbo and expect ace performance, doesn't happen like that. But you will make decent power, just not the best or most efficient etc etc. Look at the RB30 results thread and see how many are using that turbo, SFA. Then look at the turbo's they are using and the power they are making.
It will be laggy, unresponsive and probably won't last for big miles. So when your travelling from Mildura to Adelaide or something it will let you down one day, one day!!!
Thank you tridentt for that info and thank you everyone else for your input. anyone wanna buy a really really really good turbo?? haha
I guess ill be looking for a 35/40 then. then my motor will be a 25/30 35/40
Which site is best value for garrett?
cheers again
yeah been to horsepowerinabox its an alright site, prices dont seem to bad.
as for 6boost or any other site that dosnt work i prefur to see what im buying in clear writing with picture included,
http://horsepowerinabox.com/HPIAB2/prod20.htm
http://www.nengun.com/forced-induction-turbines/
http://www.vividracing.com/catalog/turbo-s...-4266_4279.html
http://www.xspeed.com.au/services.php?area=performance
http://www.tweakit.net/shop/index.php?manu...t=2a&page=2
http://shop.rawbrokerage.com/main.sc
Or mayb pick one from here?
http://www.turbobygarrett.com/turbobygarre...bochargers.html
quick breif on motor.
Rb30 Fully forged and oversized bottom end, all acl pistons, rods, seals, gaskets, bearings, n1 oil pump, underdriven harmonic balencer, block was acid dipped bored 40thou over decked.
head is Rb25det s2 reco'd, ported n polished, stronger valves, springs,
std cams, and lifters.
power fc, 2x z32 afm, hi mount, 850cc or 880cc cant remember but there denso's.
think thats about it. what turbo size would i be looking at?
wanna go big power but dont want it toooo laggy.
I made over 400Kw's with a GT35, thinking of going bigger but... make it easier.... but i'm hesitant to increase lag...
As for seeing what you buy, 6Boost is the cheapest and what ever you decide you want he'll get it for you.... and when you decide to get one of his manifolds he'll discount it for you as your a repeat customer...
I know it might seem like im flying the 6Boost flag, but i got screwed oround for 2 months when i bought my turbo, had to threaten legal action to get my money back...
Rang Kyle, got it cheaper and delivered in 5 days...
Plus you get after sale support...
mayb his the man to call. Still not 100% on the GT3540. not keen on the T04.
Im still keen on 350+ just not sure how much power my set up will do. id like to get the most out of it and since im buying a new turbo i would want it holding me back and havin to buy another one.
i deff want garrett.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
