  • Replies 3.6k
Posted Images
a couple more teams due to launch their 2010 line up this weekend
the online Mclaren one is one to look forward to with button and hammo. going to be a very intersting team dynamic there
Does this mean that Maclaren will be getting Customer engines from Mercedes ?
Will homo\button be getting the Shuey spec or less ??
will all the Maclaren fan boys defect to the silver arrows ?
Cool I say ...Forza ferrari :)
cokey
Ditto. I'd wanna be able to, seeing as I am a McLaren fan boy :)
Got the email from McLaren about their online live launch, but I'd probably have to watch it at some god forsaken hour, let alone hope my pathetic internet connection holds on.
EDIT: It will be 9.00PM Brisbane time, so I'll make an attempt
    • If your tuner can't make the car idle like factory, I'd get a new tuner. These injectors are fantastic and I'd have very serious concerns about a tuners skill set if they couldn't get them to idle well.
    • It's highly likely you will find something. Alternatively, a quick design and order online from chaina and you'll have a perfect solution
    • Idle Lambda target is off by .4 but I reckon the VE table is not correct. If my tuner has no issue using these injectors I will keep them, they are good quality after all
    • I already have an Apexi. Just wondering if it is worth putting in something new since the Apexi is likely well over 10 years old, if not 15. I know the injectors work but they already run at less than rated fuel pressure to make them work properly and idle is basically 1% duty cycle or less. Could be better
    • Nice, I would never have thought in that direction. The actual motor is a cylinder....I wonder if there are any cylindrical heat sinks with the right ID  (and if there is clearance to other components). I think adding airflow is still a thing as well....will check it all out next time it is in the air. Wish I had a hoist...
