  • Replies 3.6k
Posted Images
Gotta love the interweb.
To make things clear.
I understand your position(s).
I disagree with them.
That doesn't make me ignorant.
My apologies. You are entitled to your opinion no matter how correct/incorrect it is.
I think you are looking at it from the wrong direction. I agree that F1 engineers and designers do not have road cars in mind when they invent a new part or technology. They are there to win races in F1 only and couldn't care less about the car industry.
What I'm saying is that car manufacturers look to F1 for ideas and new technology and use what they think can be applied to their production cars.
Whether this is purely for "fashion" or not, there is no denying this occurs.
Anyway, enough of dribbling over splitting hairs, who's going to win the next GP?
Red Bull and Mark Webber anyone?
Bernie once again taking F1 to parts of the world where nobody gives a shit. Its NASCAR country where even IRL dont do as well. What hope has F1?
Anyway, looking forward to seeing the crowd of 10-12 people in the stands for the weekend's GP. I wont dare bet who will win in the sphincter of the universe. I personally think Ferrari are overdue for a good weekend and think it will be close between Nando and RBR, possibly Massa rememberign what made him quick around there
I'd rather see them keep the classic Euro tracks than take it to places like Texas where they couldn't care less.
As much as I'd like to see the Ferrari's do well this weekend, I think RBR will still be the team to beat. Ferrari is going to try their new rear wing (from Spain) again tomorrow. External threats could come from Button and Kubica also, potentially even Rosberg and Schuey but not likely imo
I just don't understand why they didn't consider Watkins Glen, Road America, Road Atlanta or even Laguna Seca... Throw 20-30-40 mil at any of those circuits, make a few changes to the track layout, upgrade pits, grandstand and facilities... Viola! But noooooo... Bernie is a comple f*ckwit...
Webber a New hope? Vettel Strikes Back? or the Return of the Fez?
Edited by Marco-R34GTT
US GP for 2012, in Austin Texas!
Texas US Grand Prix!
Austin 3:16. Why? I don't bloody know!
I agree with the other post that the US has several worthy tracks already. Why they're building a brand-new road course in SOUTHERN America (NASCAR country) is beyond me. This will probably flop. I hope to be proven wrong, but all I can say is I'm glad it's not my money.
I do have to say, though, several of the US's top tracks would need more than a small investment to run F1. Watkins Glen and Laguna Seca, for example, would need extensive works to make FIA safety standards. There are a couple of sections of both where run-off is a major issue. Then again, they run at tracks like Monaco and Albert Park, which are as bad or worse.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
