Epic track, miserable weather. Bring the big pair of nuts this weekend
It's all good so long as the race doesn't get red flagged
*****Conditions of Entry*****
-BIG BALLS REQUIRED!-
Edited by Marco-R34GTT
  • Replies 3.6k
Posted Images
And, latest news is its going to be wet. And some more wet to go with your wet. Glad I am not a fan out in the rain. Should be a good contest to watch on the box.
excellent. going to be an epic race if it rains, I have tipped RBR 1-2 with alonso coming home 3rd. was a bit worried about renault not having top speed but wet race changes things.
I am not fussed about all this RBR wills struggle. Vettel blitzed them in Valencia. Webber grabbed P2 in Canada where he would have had a top 3 finish had he not been d1cked by gearbox problems. Spa has more high speed corners then Canada so I think RBR will be fine. Both cars easily in the Top 5. Probably top 4 as I dont think Button and Massa will get their shit together.
No cars on track so lets turn the attention of the cameras to HOT Belgians in the crowd. I approve!
But seriously, Bernie really needs to allow the teams to run a 3rd car on Fridays. You travel all the way to a GP, you dont want to watch an empty track! The support races area a joke with only 3 support classes running. Young guys need seat time, teams need to develop parts....its on a race weekend so the team are there anyway. The only question is pit space, with only two cars allowed on the track at any time from the one team. You have the potential of having a car circulating for 45-60mins of the two practivce sessions while the lead drivers do minimal work for the weekend
...and lastly, HRT you are a joke. Benching Karun for the mad crash test dummy who is slow to boot, especially with Klein sitting in the pits :P You are a JOKE!
95% of rain for Quali. Webber was looking quick in P3 until rain came. Vettel a fe problems :ermm: Each RBR car has had a hiccup in each session. Often teh way, i remember China last year they killed them when they were chasing their tales all through practice and quali...its happened a few times. I am hoping its a charm :)
Awesome lap by Webz, got the job done early on his first go when it counted. Hamo blitzed his quali lap with damp Turn 1! He will be happy with P2...it will be a real interesting lap 1.
So...i am off to get hammered to see if i can get me a Desi girl my last weekend in India :ermm:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
