  • Replies 3.6k
Posted Images
come on alonso. do a vettel and blow that f**ker up!!!!
poor webs. if he'd kept it on track he'd have had zero points for vettel, 25 for himself and alonso with 18 points would now be in second place 21 points behind webber... :worship:
as it is webber's goose is not quite cooked. vettels blow up gives webber a lifeline. but f**k me dead webber picked a bad race to have a little f**k up. he's been bloody good this year with no f**k up related DNFs and only 2 DNFs in total. very bad moment to have one. :)
I've still got faith. come on webber!!!!
ALONSO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PS can someone please pm me a racing underground invite? I haven't been on in a year or two and have can't find my account. I'm a good seeder... :worship: promise.
I'll see if I can swing one your way.
I've got none left Mr baron, sen steve a pm i gave him my last one.. perhaps he might have gained a few
i want my 17:1 its looking a bit worse after this race now but with vettel out its lookin a little better..
i wonder whether planetF1 would call this boring or exciting in their poll? sure it was important championship wise, but surely that doesnt make it interesting by default?
anyway, the 'track' looks like its here to stay so who gives a shit ey
with nando due to have his engine let go pretty soon, its all still on. Brazil should be good, always things happening there
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
