  • Replies 3.6k
Posted Images
hammo throwing it sidewayzzzzz
vettel looks like he just needs mark to hold onto his tail in the race, and he's got it.
I think Vettel will definately tussle for the win with Alonso and maybe hammo, but mark will be somewhere in the top 5... Shafting noobody but himself
But here is the thing, forget the fastest time, track isnt fully rubbered in and a whol ehost of reasons why the fastest lap is not so important....did anyone notice on the long runs the RBRs were 0.5-0.8 secons a lap quicker with full tanks and the option tyre! Their race pace looks convincing for one of the few times on a Friday
How the hell is button so much slower than lewis? and why isnt anybody giving him a hard time like they are for massa's shit pace
I think he's mentally finally accepted his number 2 roll in that team.
And webber... come on man. You need to get in front of that fucking german, he's clearly been faster for months now, and if really want this title your going to have to work just a little harder for it
He needs to get in front of that Spaniard, let alone the German :)
Hamilton being fastest is actually good for Alonso. I hope Redbull pull something out today.
All over after P2...
Time to grab a cup of nice warm tea and calm down.
I know, I was just being melodramatic :P:O
When they say each driver only gets 8 engines for the year, is that just the block? Are they allowed to fully rebuild the engines and replace all internals? If not, what's to stop them doing it anyway, since the FIA can't be monitoring those engines 24x7?
Thought they couldn't open them up. They have a few of those little stickers around the engine joints saying "void if broken" :P
the bolt heads would be sealed with tamper-proof indicators
it's not as if they just trust the teams not to open 'em up
back when it didn't matter, Ferrari used to go through around 150 engines per season...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
