you bastards.
i asked if there was going to be cruising, and most of you turned around and said nah.
bugger i was always up for a cruise, sorry you missed out mate, donnan showed up later aswell
I'd blame low200 cos i was late so i can't be blamed lol
https://www.sau.com.au/forums/topic/30059-spotted/page/396/#findComment-3003126
spotted sinista at the BP servo last Friday (would have posted earlier but have had no internet :) ). Had a chat and even managed to talk him into giving me some money.. hehe ;)
I see you made it to the dinner then Richard.. going by posts above ^^ ...unless you just went cruising :D
https://www.sau.com.au/forums/topic/30059-spotted/page/396/#findComment-3008258
Gave/got a wave from a maroon 33 waiting at the closed off road thing they have going on on Cotter road, and gave a wave to a silver stagea coming up the hill on william hovell drive, but received no love in return :)
'twas probably my car, but the missus would have been driving.
Spotted Luke in his White Stagea going past Calvalry hospital this arvo, shiny new wheels.
https://www.sau.com.au/forums/topic/30059-spotted/page/396/#findComment-3010262
Yea i got an pm/invite about it but was in Melbourne... PGA (Pulsar Group of Australia) had a meet up and a fair few guys/gals from Sydney came down.
oh and about a million pulsars in woden on sunday (what is the collective of pulsars? an sr20 of pulsars?)
https://www.sau.com.au/forums/topic/30059-spotted/page/396/#findComment-3011540
Just had a Moron, I mean Moroon 33 tailgate me through Weston towards Kambah. If your on here, next time back off would ya, I couldnt see shit from those bright arse headlights (or were they highbeam?). (i was in the troopie)
https://www.sau.com.au/forums/topic/30059-spotted/page/396/#findComment-3014185
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
