  • Replies 169
Matt - GTTR34
Shanu - Shanu
Nick - GTS-T_Sedan
Niroj - Basti
Charles - Charles89
Jamie - (OO)SKYLINE(OO)
Leigh - UNR33L
JD - jezza boii
Himself - eMsta
Himself - ashneel
Adam - Birds
Tom - atomaly
AP - LEANBAC
Cam - iamhe77
Jonnie - WGNC-34
lets hope my Vy can cope, she's on her own haha
Stop terrorising the newbies matt :cheers:
What do you mean on her own TJ? that isn't allowed to happen. Annnd i AM in the neighborhood at that time...so...put me down at this stage :santa:
ok people.
next wednesday the 30th 630-7pm meet up at the car wash, sorry don't know the name of it, hang around for 15mins and leave at 645, get to the shops and be ordering at 7. Pizza and chicken shop next door for food :cheers:. Hope to see an alright turn out.
And i'll find out if im not working during the day, and if no one else is we can make it earlier.
Whats the address of the carwash?
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
