Hey guys,
Well I bought an R33 auto coz im lazy (arent we all) but I'm kinda missing changing gears :D
Was thinking about doing a manual conversion, but like I said I'm lazy so I dont want to get stuck in traffic and have to do it all myself!
Anybody got any thoughts on putting in a tiptronic transmission? Is it even possible? I know it was an option on the R34's but how would I go slapping one in an R33??
Any feedback much appreceiated :(
Cheers
https://www.sau.com.au/forums/topic/30085-tiptronic-conversion/
Haha sorry, No idea actually. I don't thnik tiptronic would have the same affect as you still only have 4 cogs. I'd go the manual conversion instead of tiptronic. Just my idea but yeah, much more fun in a manual, especially a turbo
I think there was a sequential shift kit floating around somewhere. Not sure what company, and i think it was for a WRX - but that could be a possibility?
sorry, but i don't know about auto to steptronic conversions...
i have been thinking about this too as mine is auto. I think it will cause alot of problems trying to get it working properly electronically speaking. I dont know if the 34 tiptronic box has its own ecu to the main one, but it would need something to tell it what to do.
I think putting a r34 ecu in the 33 would cause problems too. I would like to hear if someone has had success doing this though
Guest RedLineGTR
do much electronics to muck around with and will cost you a arm and a leg with the auto electrician the r34 triptronic has its own ecu which would also have some connections to the r34 main ecu which would cause problems. Too much ****ing around..also you would need the console for the gear stick made up etc cost extra money too..My 2 cents
  • 5 weeks later...
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
