Thanks Santa (the neverending trials of the 400,000klm, 400kw, RB30, manual swapped Stagea)
Well it has been a while, but I picked up the car from Hills Motorsport yesterday.
It got dropped off as a standard engine bay with a pretty sick (not sik) motor. It came back like this:
Basically it has an rb30 bottom end, skyline rb25 head, forged rods and pistons, new bearings, seals etc etc.
High mount ebay nugget t3/t4 turbo (go china!)
Front facing plenum
Pretty much everything else as before (powerfc, manual, sydneykid shocks and springs, d2 8spot front brakes).
So far its only being run in so it hasn't been pushed or tuned - but the torque down low is amazing and a real turn around from the normal (slightly disappointing) standard stagea feeling.
Turbo is making 7psi at 2,000 so I'm sure it will come on nice and early as I hoped, the run we did at 10psi had 160awkw which is a little more than the old setup made on 14psi - but the response even off boost is the real difference.
Very happy A+++ would buy again!
Congratulations! Good to hear. I got an RB30 bottom end (not installed as yet) because unforged it will stand more kw than the RB25 unforged and also have more torque all round . I would guess your engine will make around 280 - 300awkw now and have the potential for much more if you choose! [would you mind PM the drive in drive out price to me? I expect mine will be a little less because I am not getting forged rods and pistons and the front facing plenum will have to wait].
I bet you are a happy camper.
I drove around the yellow thing around today and all I think about is how another 500cc or so would make the car a whole lot nicer to drive in traffic.
How much did you spend on the new motor?
yeah it is beautiful to drive, especially pulling away from idle. no idea what it will actually end up doing, I was aiming for about 250kw but a focus on torque.
If I ever decide to get silly it has all of the required supporting stuff except injectors and an expensive turbo to go 300+.
Cost was about $10k but that did include some other stuff like a new alarm, clutch, intercooler etc etc.
I was going to keep the standard manifold but there may have been clearance issues to the bonnet, and the china front facing manifolds are dirt cheap these days.
$10k . . . i dont think i could ever part with that cash with out getting reamed by the miss's haha.
in one go though. here and there easy, but in one hit.
would have to spoil her for a month before to soften her up
I'd be pretty happy with that for $10k mate. you've got the goods plus a very clean, professional looking job.
if i may have a small nitpick though ( ;) ), it looks like your heatshield/airbox is covering/including your charged air intercooler pipe. it's something small, but i'd be keeping that on the outside of the airbox :P
edit:
tj, you've picked the wrong one! i've already pre-approved a $30k supra with mine ;) i'm still working on the 30k engine package though :):(
Edited by pyro-ns
Pretty good drive in drive out price
Other expense that you have not listed is the sump adaptor to suit the awd sump and rb30 block. These are not cheap
Could you find which one they used and the cost of it?
if i may have a small nitpick though ( :blink: ), it looks like your heatshield/airbox is covering/including your charged air intercooler pipe. it's something small, but i'd be keeping that on the outside of the airbox ;)
yeah I am very happy with the price. $10k is a lot of money, but you have to look at how much time and parts there are in this build. I beleive it was very cheap for the work that was done. Good call on the cooler pipe, might see what I can do.
Nice, were there any issues getting it in and running, or was it all fairly straightforward?
nothing but trouble getting it running, but nothing to do with the job the shop did. For instance, once the whole thing had been assembled and put on the dyno the first time they discovered a crack in the block at a welsh plug at the rear of the head. I hadn't asked for it to be xrayed, they took a chance and lost. And then the second time it was put together the f**king alarm control module failed - but of course that is the last thing you think to check.
and of course the R34 GTT PFC is not a direct fit in my car which needed some stuffing around too.
once it was all together it has been fine though, and the run-in tune was quick and easy. Idle control has been a bit of a pain with the new plenum/throttle/cruise control/aac mvoed etc etc but its all good now.
Looks good!
what throttle body did you use on the plenum?
pretty sure it is the standard tb - I am not looking for more than 300kw from this setup and I'm sure the standard one will be enough for that.
yeah they used the pro-engines sump adaptor, about $800 including all fasteners from memory, fit first time without any mods required. also another complexity in a 4wd/rb30 is the oil pick up because the rb30 point is right where the driveshaft goes through the diff. the guys at hills modified it to plug the normal hole and drill into the block at the right place same as a 26 block - very precise work required to get that right. often people just run external oil feeds to the pump, that is probably both cheaper and easier.
once we have a house, the women don't care where my spare cash goes josh :blink: but for now it would be hell haha
lol don't you beleive it! once you have a house you have kids, then it's ALL over.
lucky you have the best wife ever eh Duncan?
:blink:
(and yes, I have a built in radar which automatically detects any thread you post comments about spending money on cars in)
Nice mate!
If you're going Chinese for the intake plenum (the greddy knockoffs) make sure you check for leaks before you drive it away. Look especially hard at the.. stalks? where it comes out of the engine, mine had a pinprick - 1 drop and thanks to the tuners these guys found and fixed it!
Leaks are easy to fix if spotted right away - a cooked engine is not what you want!
But that is bloody tidy, I've just had some work done myself, so I'll put up my build thread when I get a proper camera
Its not over. You wait till your 66. :cheers:
Child slavery was invented by parents who wanted to still be able to afford such luxurys as motoracing.
nice work Duncan, the 30s do drive alot nicer than 25/26 capacity motors, especially in stop start traffic they just pull away from idle with ease.
You can buy the internal oil pickup with the pro engines sump adaptor kit and it bolts straight on without any hassle.
One thing to mention is when choosing this combo i feel a small turbo is not such a good idea (not aimed at you duncan). I run a 3076r on mine and it suffers from incrediblely shocking fuel economy, due to the car sitting on 0 on the vac/boost gauge at 100kmh on the freeway. Mines making over 20psi at 2900rpm which when on 100kmh on freeway its sitting on 2700rpm or so doesnt leave much until its wanting to get onto boost.
Im going to bolt my t04z on mine and see how it is, then probably get some 2860-5 lowmounts for longterm to keep it looking stock (i run 26 head)
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
