Do any race cars run stock airboxes?
Plenty,
Including some of the hotter factory specials like the Nismo versions of the GTR of various flavours Z tune , R tune etc..
The mines R34GTR has stock airbox/ BOV, a lazy 600+ HP and notorious response.
Someone can try and tell people it doesn't sound good but, they will be seen as being faggy for saying so.
Why pay money for Pods when they are a step backwards in power on a GTR without a cold air box and feed?
Even with a CAI forking out over $500 to set it up nets you at best 2hp or so. It's what you call a good waste of money. $500 is better spent on something else.
Plenty,
I found this pixxor of an Mines R34 GTR replica.
Doesn't look stock to me.
I believe sav_man's 33 N1 which he ran Targa with is the stockest I've seen with just exhaust system done and ecu. Everything else is stock. Pushing more than 300rwkw with more than 95% duty on injectors. So yes it can be done but it all depends on what your objective is. For his, I think he just wanna keep the whole N1 version of the car as much as possible.
Councillor: Do what everyone suggested. My pick for exhaust would be Kakimoto Regu 06&R because of the very distinctive RB brumble they have (yes I've heard a few exhaust and by far, the Kaki's the most distinctive) and the "titanium" looking tip (if I hadnt got my Trust TI-R, I would be getting this). But if you prefer quieter ones, get the HKS Slient. The HKS one will be loud or sound good on high rev but on idle, its pretty docile.
Ultimately if you're not after high power, getting an ecu after the exhaust's been done is required. You will be amazed by how much difference a tune can do. Not so sure about the oil cooler though (its a good to have for street car imo, not a must have). If you need it, get it. If not, dont bother. I wouldnt have a clue because mine came with the factory oil cooler.
I'll say this, DO NOT get dumps for your GTR unless you're doing turbos too. The labour cost is ridicules if you're just doing dumps. And if you're not running really high power, its probably bugga all difference.
Targa rules say the intake system (including Injectors) must remain standard!. Also the car must run on a standard ECU, in other words you can change your ECU so long as when the scruitineers plug in the original ECU the car must run.
Ash
http://www.skylinesaustralia.com/forums/R3...-s-t301285.html
Looks like a good buy for 500bucks. Maybe look at that before sourcing something new.
Ash: Thanks for the info but yea, sav_man's N1's running very well for a stock car.
That particular car has plenty of 'similar performance mods' but, is actually a 'replica' meaning it's not built by mines. It has plenty of extra modified bits that aren't the same as the mines car.Although quick, It's slower than the mines car.
have a look at the vid link I posted and you will see the stock airbox. they even point at it for you.
There have been some back to back tests on the stock air box that prove it's not a power restriction.
They are a good thing from factory. I guess they have been homiligated for motoracing so the factory item must be good.
Ash
Yes thats what I heard. Thats why my advice to TS is not to do that many mods unless he's got plans for really higher power. Personally I feel after tuning, the car already is very quick and enjoyable.
Some good advice from a GTR owner.
On GTR's the 'bolt on boy' approach can see your car go slower and be less enjoyable to drive. Planning out what you want to improve carefully will see you get the best results. Always consider carefully the 'why' before handing over of cash. And it does take some time to filter out the good advice from the ordinary on these forums. It's worth it though. :D
Yea... work out whats a MUST have and what are the GOOD TO HAVE items. Most of the time I see people spending heaps on good to have items and its really make the car a money pit when you add everything together. Its like Macca's upsize, 1 dollar more you get more but ask yourself, can you finish it?
black rims on silver body makes me f....ckn yawn = boring as hell
Sound like a boost comment. If the owner likes it, I dont see a problem with it.
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
