im interested in this. I think my standard coil packs are playing up so im after a cheap upgrade also. A mate was using these bosch coil packs which were really cheap, they were mounted on in the engine bay and had plugs runnign to the top of the coil packs. This was on his CA18det. He said that he thought that maybe aftermarket management was needed to run them though but he wasn't sure.
I'm interested in this thread.
Sydneykid - what sort of set were you running for the 625 bhp - ie what boost and what turbo, what sort of intercooling ?
Cause I would have thought this would be a contributing factor. Ie if you are running high boost, small turbo, less efficient cooler, the coil packs might break down. On the reverse side if you running all the right gear you might be fine.
On my old setup - (240rwkw) the workshop guys said my coil packs were breaking down. (Spark blowing out)
On my new setup ( >240rwkw) they are fine. And I have changed a lot between the two setups. (but not coilpacks)
Also, the guys that told that the coli packs are were breaking down could have been spinning a whole bunch of porkies.
So how do you tell if your coilspacks need to be upgraded ?
Hi B-man, that a fair comment, 625 bhp is not the same loading on coils if the set ups are different/compromised. But I don't believe in using stronger coils as a bandaid, if you have a problem with heat, then fix the problem, don't cover it up with stronger coils.
My experience has been plug gap is most variable, we run around 0.8 mm (some plugs come standard at 1.1 mm). So WHITE R32 that would be my first port of call, check the plug gaps.
A lot of shops will tell you the coils are breaking down, after all there is money to be made in selling and/or fittling a new set of coils. Not a lot of money to be made in regapping the plugs.
Hope that helps
Merry Xmas to all
Hi Buster, if we upgrade coils we use Mercury outboard coils which are designed to be used with CDI. They are OK value at $75 per coil. We also use a Motec CDI to fire them, not such great value at $2,500. But our experience has been this is the only worthwhile step up from standard coils. Autronic CDI's have also worked OK and are a little bit cheaper than Motec's.
So if I wanted/needed better spark than the (pretty damn good) standard coils deliver, then a CDI and CDI coils would be the only way I would go.
Hope that helps some more
I've noticed the NKG standard coppers with a .8mm gap would cause a slight surging or power dip type feeling when running high boost (1.1-1.2bar) and lots of timing.
I did a little test with the NGK copper V-grooves (BCPR6EY) and they are definately better. It is noticible. The car rev's easier up top and pumping 1.1-1.2bar in to it doesn't make the car faulter with power dips/flattening out. I've also been able to pump the timing back in to it.
At first I thought they were just a gimic but after going from V-grooves to standards then back to v-grooves there is a definate difference.
My first set were BCPR6EY which have a preset gap of .8mm which is perfect.
The second set I would have had to wait 3 weeks to get them so I got the BCPR6EY-11 which have a preset gap of 1.1mm hence the -11.
They only appear to make a difference when running high boost and lots of timing. Stock setup I didn't notice any difference.
I noticed that there is a definate difference with the electrode with the standard plugs and the V-grooves. The V-grooves look slightly longer well the white stuff around the electrode.
Don't get the BKR6EY like some state as they have the incorrect height. One is a jap standard that is a few mm taller than the other BK plugs.
I'd be curious to see if Sydneykid has had any experience with the V-grooves and if he thinks they are a good thing or not.
i have been thinking of the splitfire coils as something for the future only due to past experence with there products, i also use their performance v plugs in my rb20det and their leads and plugs in my rb30e in both cases i've had no problems and produced more power, from what you guys have said i'll keep my standard coil packs and just use good plugs!
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
