Here's Duncan and I, having a bit of fun with our in-car from the recent Mt Buller Sprint
(well you can't expect anything Duncan's associated with to be serious).
For the first time ever, hear what the nav actually says and what the driver actually hears during a competitive rally stage :wub:
Mt Buller In-Car: Handley & Handley
*UPDATED*: For those with short attention spans... here's the prologue :)
Great video Kel...maybe next time, lose the music so we can hear ya a bit better.
Music and Incar don't really go together unless you dont have intercom audio. As an added benefit we get to hear that RB sing :D
I wish mate....all I can hear from her is white noise!
nah we are just having a bif of fun, I actually do pay attention to Kel and she did an amazing job with the calls.
and the poor old rb wasn't singing....7psi thu a gtr is more like a crime than singing :D We will have it sorted properly next time.
The real gold would have come if we'd had sound from Duncan - something we're getting sorted for Lake Mountain.
We had a very sophisticated set up at Buller, consisting of the cam mike taped to the side of my helmet after having adaptor problems.
This was a fairly tame run. On a few of the later ones I was telling D to fark off and pay attention to me (along with some other choice phrases!).
Running the same road over and over makes these drivers a bit cocky and D was calling some of the corners before we got near them (and calling them mostly wrong mind you) :D
Will post some serious (no music) runs when we get our issues with uploading to Youtube sorted.
Wish I knew it was you guys off here - I was the guy that found and returned your Buller Sprint "ID" Kel! :D
Ahh thanks again for that and sorry we didn't know you were there - would have been good to catch up with another SAU-er!
So you were supporting Danny Cerro and Bianca in the Evo? We were speaking to those guys toward the end and they were really bringing down their times (dropping a minute from memory?).
:banana:
Yeah, I was. They did drop a minute between their first and tenth run. More importantly, they kept themselves and the car in one piece.
Definitely the most important thing as it's not a road to be messed with as many discovered, including our mates in the TR7:
TR7 Off @ Buller
They were pretty lucky- just stuck on the bank with no actual damage to the car.
They did have a moment though when the exhaust heated up some dry leaves!
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
