when i go to accelerate from either a standing start or between gears the car hesitates, goes lean and kind of sputters a bit then goes back to normal. if i accelerate SLOWLY it doesnt do it, and when i accelerate HARD it doesnt do it, im not sure what it is. i tried checking for leaks in the vac/cooler system with no luck.
i took a vid to see if it would help identify the problem. the gauge on the left is the wideband and you can see the pressure/vac/accelerator position on the gauge on the right.. turn up your volume so you can hear what the car is doing.
http://www.youtube.com/watch?v=xPHSLI50Kd4
cheers guys
Edited by SECURITY
https://www.sau.com.au/forums/topic/301603-almost-stalling-on-acceleration/
well unless he has wired the wideband backwards or some crap, it's definately going lean...
It is a tough one! Maybe there's a small block in one of the injectors? Or the pump isn't getting enough voltage or something? Other then that... I was thinking a stuck throttle body but that wouldn't lean it out...
sorry, shouldve given a run down on the car
its got a vipec ecu, it does it under any load, i tried changing the tune around (the vipec has a 1-100 range) i went from 42 in the cells up to 60 and it didnt change much, im pretty sure its a mechanical issue.
My mistake...I didnt see the AFR ratio thing on the left...Definately sounds like some kind of fuel issue. Highly doubt its ignition ( although I could be wrong )....Has anything been done to the car recently ..like prior to this problem occuring ?...Maybe a vacuum line got knocked loose
Edited by GTR-32U
Not sure about the vipec ecu but I had a similar problem on my VH41de safari running a link ecu, it turned out to be an acceleration enrichment issue.
i think you might be on to something, ill have a play around with the accel enrichment tables and see where it gets me.
cheers guys
accel pump adjustment
this car has not been tuned yet has it?
not properly, i had it on a dyno after the engine was rebuilt by the engine builder but the new injectors and plenum havent been tuned in properly. i got it running pretty well using the auto tune and the m5, but this problem just started randomly though.
the accel enrichment didnt work. it didnt change at all. i think its something mechanical rather than the tune.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
