when i go to accelerate from either a standing start or between gears the car hesitates, goes lean and kind of sputters a bit then goes back to normal. if i accelerate SLOWLY it doesnt do it, and when i accelerate HARD it doesnt do it, im not sure what it is. i tried checking for leaks in the vac/cooler system with no luck.
i took a vid to see if it would help identify the problem. the gauge on the left is the wideband and you can see the pressure/vac/accelerator position on the gauge on the right.. turn up your volume so you can hear what the car is doing.
http://www.youtube.com/watch?v=xPHSLI50Kd4
cheers guys
Edited by SECURITY
https://www.sau.com.au/forums/topic/301603-almost-stalling-on-acceleration/
well unless he has wired the wideband backwards or some crap, it's definately going lean...
It is a tough one! Maybe there's a small block in one of the injectors? Or the pump isn't getting enough voltage or something? Other then that... I was thinking a stuck throttle body but that wouldn't lean it out...
sorry, shouldve given a run down on the car
its got a vipec ecu, it does it under any load, i tried changing the tune around (the vipec has a 1-100 range) i went from 42 in the cells up to 60 and it didnt change much, im pretty sure its a mechanical issue.
My mistake...I didnt see the AFR ratio thing on the left...Definately sounds like some kind of fuel issue. Highly doubt its ignition ( although I could be wrong )....Has anything been done to the car recently ..like prior to this problem occuring ?...Maybe a vacuum line got knocked loose
Edited by GTR-32U
Not sure about the vipec ecu but I had a similar problem on my VH41de safari running a link ecu, it turned out to be an acceleration enrichment issue.
i think you might be on to something, ill have a play around with the accel enrichment tables and see where it gets me.
cheers guys
accel pump adjustment
this car has not been tuned yet has it?
not properly, i had it on a dyno after the engine was rebuilt by the engine builder but the new injectors and plenum havent been tuned in properly. i got it running pretty well using the auto tune and the m5, but this problem just started randomly though.
the accel enrichment didnt work. it didnt change at all. i think its something mechanical rather than the tune.
    • Spotted in Adelaide last week.... mine! New to me two weeks ago.. love it!
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
