ive herd alot about high temperatures under that coilpack cover... if its bullshit meh if its true... well ima go outside n rip mine off LOL i wana get my cam covers chromed... duno much about what metals u can chrome... can u chrome cam covers off an rb20 ?
you can.... but chroming alloy doesn't work very well and it will start to flake after a while.
also removing the CAS is it only the angle of the actual unit that has to be marked to put back, or what if the spinning bit on the back of the CAS moves?
doesn't matter if the spinning bit on the back of the cas moves. and even if you don't mark it, if you have a timing light you can set the timing to 15 degrees with the timing light rather easily anyway
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
