DO NOT get one from a wrecker, always replace this part with a new one, 2nd hand ones are too brittle.
i doubt supercheap and repco would have it, you may need to go to a private parts shop and they will usually sell you a part that will fit, thats where i got mine, fits nice and snug. otherwise just go to a nissan parts dealer.
if you're going around to private parts places i suggest taking the PCV (the dark plue part) and taking it with you so they can get one to fit right. after that its a case of putting the new seal into the rocker cover and sliding (forcefully) the PVC into it.
also, make sure all of the rubber came out when it broke, otherwise you will have some in your head.
Edited by SECURITY
https://www.sau.com.au/forums/topic/302087-hose-problem/#findComment-5011828
to me the pcv valve looks okay its the rubber that is broken. you can buy the rubber from nissan for $21
i agree
last person to touch that gasket/gromet put it in backwards - the conical section goes inside the cam cover (might get away with just swapping it back to the correct direction)
https://www.sau.com.au/forums/topic/302087-hose-problem/#findComment-5015621
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
