Hey guys
I'm a little stumped on how this happened so I though I'd get some suggestions. I did a search and found differing ride heights on other skylines but mainly due to old springs sagging.
I recently fitted some new (second hand shocks) and new TEIN S.TECH springs on the car and everything was fine. It lowered the car about 20mm ( the maximum rated is Front:32mm, Rear 30mm drop). I measured the heights at the fronts and they were the same and both rear heights were the same as each other.
Whereas now about 2-3 weeks after I measured the ride heights (measuring from centre of wheel to guard) and I get these
Front Left: 355mm
Front Right (drivers side): 348mm
Right Rear: 353mm
Left Rear: 348mm
Now these might be 1 or 2 mm out, but you get the idea . The front left and right rear are a bit higher than the others (and yes the concrete was flat). And considering when I measured them after the install they were fine.
The only thing I can think of was I gave the car to PEDDERS and they did a wheel alignment and put some pineapples in the rear. Now I don't think that could change the ride height could it?
Thanks in advance
https://www.sau.com.au/forums/topic/302205-uneven-ride-height/
due to the camber of the road the driver side of the car should sit a little lower then the passenger side
really? i'm not going to straight out call bullshit, but i have my suspicions..
not all roads have a large enough crossfall to warrant jacking every car up on the right hand side
Hey guys, thanks for the replies
Ye I did put them in myself, but from memory I couldn't remember seeing anything on the rear springs indicating a Left or Right side. And looking at the two they didnt seem different lengths, but I guess a few mm is hard to see.
I know that the front drivers side sometimes gets a little bit lower over time due to the weight of the driver but its just strange that it was fine for like 2 weeks and then now it becomes all uneven. Unfortunately I have damper adjustable shocks but not height!
So does anyone else have any ideas? Or did it just take a while for the suspension to adjust to the different weight distribution on the car?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
