Hey guys
I'm a little stumped on how this happened so I though I'd get some suggestions. I did a search and found differing ride heights on other skylines but mainly due to old springs sagging.
I recently fitted some new (second hand shocks) and new TEIN S.TECH springs on the car and everything was fine. It lowered the car about 20mm ( the maximum rated is Front:32mm, Rear 30mm drop). I measured the heights at the fronts and they were the same and both rear heights were the same as each other.
Whereas now about 2-3 weeks after I measured the ride heights (measuring from centre of wheel to guard) and I get these
Front Left: 355mm
Front Right (drivers side): 348mm
Right Rear: 353mm
Left Rear: 348mm
Now these might be 1 or 2 mm out, but you get the idea . The front left and right rear are a bit higher than the others (and yes the concrete was flat). And considering when I measured them after the install they were fine.
The only thing I can think of was I gave the car to PEDDERS and they did a wheel alignment and put some pineapples in the rear. Now I don't think that could change the ride height could it?
Thanks in advance
https://www.sau.com.au/forums/topic/302205-uneven-ride-height/
due to the camber of the road the driver side of the car should sit a little lower then the passenger side
really? i'm not going to straight out call bullshit, but i have my suspicions..
not all roads have a large enough crossfall to warrant jacking every car up on the right hand side
Hey guys, thanks for the replies
Ye I did put them in myself, but from memory I couldn't remember seeing anything on the rear springs indicating a Left or Right side. And looking at the two they didnt seem different lengths, but I guess a few mm is hard to see.
I know that the front drivers side sometimes gets a little bit lower over time due to the weight of the driver but its just strange that it was fine for like 2 weeks and then now it becomes all uneven. Unfortunately I have damper adjustable shocks but not height!
So does anyone else have any ideas? Or did it just take a while for the suspension to adjust to the different weight distribution on the car?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
