  • Replies 51
Yes Danny just asked me to post saying this ..
"Gary,
I would prefer someone just posts saying these are not ready for sale for at least 3 or 4 months. No more info than that really. Can you do that for me please? I don’t really get into the forum thing much any more."
So i will keep in touch and update or Steve will at a later date. Something to look forward too anyhow.
Gary
The NEO has lower valves lift than a stock RB26 head and you aren't you stuck with the single neo intake cam? Also I'm not sure about what rev limit the head and cam controller might impose. Aren't there as more people putting RB26 heads onto RB25s as their are people putting NEOs on RB26? So it might be one step forward and one step back.
The hks vcam kits come in 3 flavors, with the pro model having higher valve lift than stock, and wider degree change, the most aggressive cam profile, plus it is rated to 8500 rpm.
Another thing I found out in the fine print is the hks vcam (like the NEO) operates on oil pressure so the stock oil pump may be on the borderline, especially if your oil is too thick.
edit: I think the r34 NEO is variable, not off/on.
Edited by moneypit
Hey, Moneypit. Congratulations on the result. I am very interested in the HKS software that was provided.
We could not get anywhere with the HKS Valcon, after lots of trying - long story, better told by Steve one day, including talking to the likes of Abbey Motorsport in the UK and HKS in Japan - whilst Haltech were offering a better potential result. (It's my car at Garage 101.) A slight problem with an N1 oil pump has set us back just a smidge, but I am looking forward to the next few weeks!
Cheers. :D
MLCrisis I think in the end you'll be glad you stuck with it..
the story with the software was
a) Local HKS wouldn't help, because the v-cam was sourced from overseas
b) Mark from Abbey sent a copy of what he uses over, but it couldn't be made to work either
c) The controller was used to input a low resolution map, which worked but I've no idea how well because the tune was so bad
d) Visiting HKS guy left tunehouse with the Japanese language software which was used to program the valcon properly. The map, as you know, is just RPM vs Load.
could you have done what RacePace did and just use a PowerFC? don't know how many drama's they had... but didn't seem as bad judging from tangomatt's thread?
I might be wrong but it really doesn't matter what ECU you have, power-fc, or f-con, or haltech or whatever.
none of them either help or hinder the install and tune of the v-cam/valcon.
My drama stemmed from two things, first, buying an HKS product out of territory. For their flagship stuff
they are really fussy about that. And the second problem was unrelated to the v-cam and was just a series
of poor decisions on my part about where to take the car, and to not retrieve sooner when it became obvious
they were out of their depth..
If I was in melbourne and had gone straight to Racepace it would probably have been done, dusted, and
with a similar result, six months ago.
Nice work moneypit, good to see more people experimenting with VCAM.
Tangomatt has had a very impressive result with VCAM although he is using an HKS 2.8 bottem end and -5's.
With the 2530's it would have definetly woken them up a bit.
Awesome result...
Don't say it. I keep thinking: 2.8. Just another "wafer thin" 200cc. I'm stuffed already but I could stretch
for that. To round things off.
And Abbey Motorsports seems to think that small difference in cc pulls spool forward dramatically.
but what a pain.. What, $10k? for the kit. Engine out. pull it to bits. Engine back in. New tune. More than $15k I suppose.
But first and maybe last, the exhaust. Then see where that leaves things.
Your right, where does it end???
Definetly a 15k exercise, I say leave it and see how far you can go with the 2.6.
So what options are you looking at exhaust wise?? This can make or break your setup....
There are so many factory setups out there now with vcam's, its a wonder noone has done it (commercially) before..... maybe perceived lack of interest.
I tell you what, i'll have it as soon as its released..... then if its only inlet cam, i'd like a second one on exhaust and go crank trigger..... yea haaa .... I can see it now, sitting in the car on the dyno for hours and hours straight , playing with the tune !
And i'm lucky to have a hi-po 3ltr bottom end on its way to me next week finally !
Gary
I'm asking after the Racepace custom r34 (ugly) exhaust 4" with the two mufflers that Benno likes to put on all his big cars, or I'm told the HKS Silent Hyper "works really well".
Beyond that, I've no idea. I don't really want it to be loud when just driving around.
Totally agree. It doesn't end. I'd love to put the V-Cam in mine but just cannot justify the cost.
You have a great setup now, just enjoy it :ermm:
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
