Ive tightened up the old Cp's a quarter of a thou...no issues at all. But the newer ring package they come with seals a lot better and really there is no need to run 3.25 thou. 3.5 thou will allow you to run as much boost as you like as well.
beware though...some guys use mild steel torque plates but they do not flex like an alloy head does and doesn't replicate whats really going on when a head is fitted to the block.
the final honing got done today :S without a torque plate.. gave up arguing with them as they recon it wouldnt make f**k all difference.. picked the pistons up from the ceramic shop so they could be measured... somehow they were all exactly 1thou bigger than the factory specifications so they honing it out an extra thou.. i had the pistons double checked by an engineering place and they arrived at the same results... when the pistons get back from the ceramic shop if they are noticeably bigger or uneven ill take everything to another shop to get torque plate honed.. but the ceramic shop said the extra clearance from the coat on the skirts doesnt effect the clearance as its a dry film lubrication layer and the skirts run colder with the crowns ceramic coated.. ill double check again tomorrow with them when i drop the pistons back off..
good to hear the newer rings seal better..
Thanks for the info guys, hopefully it all comes together even if it costs a little more
Jarrod
  • 8 months later...
The testing weve done has shown bores can be out of round by upto a thou + if not done with a proper torque plate. If a machine shop says it doesnt make a difference, take it to someone else. Also make sure you use the same headgasket and bolts/studs you are using in the build when the machining is done. This is important.
Abit late in this case...but for future reference.
Edited by r33_racer
no worries r33 racer, i was about to send my block off without my ARP main and head studs, maybe i should add them in. Overall the build up went pretty well first time around, when i first started the rebuild i had like 3k and was planning just a standard rebuild, bore ended up being rusted and stretched the budget as much as i could to include forged internals, arp steds, ceramic coating etc.. probably should of payed a little extra and gone to a better machine shop and a new oil pump.
The ring gaps ended up being huge.. they were considerably larger than the 21thou i had calculated, i was 2 weeks past the end of my holidays and decided to through it together anyway, decided to run the internal vct feed and left the oil restrictors unrestricted, had tonnes of oil going to the head and had the vct doing some weird clicking.. so going to go to an external vct, run oil restrictors and replace the solonoid this time.
Engine was running sweet for a while, had a few teething problems on the dyno and never made over 450rwhp due to it leaning out with a melted alternator bolt first time around, went to a different place second time and melted all the wires around the dump pipe.. boy do they get alot hotter once everything is ceramic coated but the dump pipe, plus it doesnt help that my wastegate runs between the dump pipe and the body of the car.
Ended up discovering that the timing belt was out half a tooth, so considering that my 450rwhp effort wasnt half bad considering it stopped early and look like it would of easily made 470+ on 21psi with low timing. the goal was 500rwhp, should make it.
had a few problems with the harmonic balancer and the keyway, whether the bolt wasnt done up enough or the keyway was flogged out, it ended up getting weird pitting all on the inside of the balancer, had to replace it along with a new keyway.
A few burnouts later i was going up a hill one night, clutched second and bounced to the limiter and got a strange knock reading, after that, whenever it hit high boost it would knock and occasional when you were driving around town at low speed it felt like was hitting a brick wall for a split second.. swapped the ecu and afm for a haltech ecu n map sensor and it seemed to fix the problem, sent the car to get re-dyno'd and the oil pump shat itself.
Pretty sure i broke the pump on the limiter and it was bouncing around still working for abit before it completely let go, possibly caused by the problems i had with the harmonic balancer.. though im sure the limiter bashing in the burnouts didnt help
whilst i was pulling the engine apart to replace the bearings and pump.. i found ceramic spark plug insulators in the exhaust, most sickening feeling.. anxiously pulled the head off only to discover the spark plugs had all came apart and trashed the engine. The spark plugs are a bit of a long story, in short i changed my usual plugs from bcpr7es to the equivalent v-notched ones, picked them up a day later to find out they were 5s and that the 5s were infact a colder plug than the 7s, took the car to the tuner with the 5s in and questioned, inwhich he agreed that the 5s were no good so we went back to my original 7s, i said they were a little bit fouled up and that i would give them a quick clean and pop them in, in which he claimed he could just give them a quick clean up by quickly burning the oil of with a oxy, bringing them up as good as new.
So rebuilding, hoping to get all the little things right this time, starting with a new block/crank, sending it away to get machined this time, getting a proper oil pump, harmonic balancer, oil cooler, cams, springs etc.. hoping to crack the 400rwkw mark with some help from the water methanol injection.
hoping this time to spend alot more time doing away with lines and wires i dont need and simplifying the engine bay as much as possible and fixing all the little things that i wasnt happy with last time
Spewing i have to wait so long to have a play with my new haltech ecu and WMI
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
