Just wondering what you'd recommend for a 235 40 18 and 16's which I think are about a 205.
Car grips up in 2nd and I think it's a combination of tyre pressure and stock power.
As for the power side of things, I'm putting a 14psi actuator on it later this week which should
assist breaking traction.
All input greatly appreciated !
Cheers
https://www.sau.com.au/forums/topic/302664-drifting-tyre-pressure/
  • 8 months later...
Definitely use the smaller tyre/rim and upping the pressure to 40psi or even 45psi, others run even higher if you're keen. Is your diff single spinning?
i put on 50 to 60 psi on my 17" 215 45.. :)
its a sunny hot day...
on wet i put on lyk 45
if its still gripping try to put more camber at the rear.. and it creates more smoke too ;)
go faster
+1 go faster = win
if its still gripping try to put more camber at the rear.. and it creates more smoke too biggrin.gif
60psi wtf lol, way to much
on a RB25 with basic mods (FMIC, fuel pump, more boost) u shouldnt have any issues at mallala getting the wheels to spin unless u run crazy good tyres
I just went drifting at Winton and my 16 225 tyres at 36 psi had no problem breaking traction in my non turbo Supra. I didn't even need to clutch kick or handbrake, I could just mash the throttle around a corner and it would kick out.
  • 3 weeks later...
  • 2 months later...
The best way to work out where your tyre pressure is and where it should be is to look at your tyres when they come off the car, this will give you and indication of how your set up is also.
Try to set the pressure's cold, do some runs, check the hot pressures and then look at the tyre, it should show even wear across the whole tyre, too much in the centre = too high pressure.
Don't be afraid of low pressures, at Eastern Creek turn 4-12 circuit at night we start at 29 degrees and work down from there. :)
Hope this helps and...
Stay Sidewayz Kidz!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
