I have a S1 R33 gts t automatic
and have fitted bilstein suspension, jasma 3" cat back, and a KN pod. For some time now i have flirted with the idea of adding some type of piggyback! Out of all the many options out there i like the PRofec e-01 and was very pleased to see the abundence of info on one of the threads......thanks guys :D (and the e-manage)
i am trying not to aspire to a 12 second line simply because i want eat and pay rent etc! I simply would like to up boost! how high boost can you go on the standard turbo and core?
the only thing i will consider getting after the piggy back is a fmic.
is the PRofec e-01 the best way to go is there a better option for me?
pete
https://www.sau.com.au/forums/topic/30271-next-recomended-upgrade/
hey pete
I dunno much about the profec e-01, but I assume that u're looking for a fuel management system of some sort. A good piggyback one is the apexi S-AFC range. I put one on my car a few months back...it gave me 66rwhp right off the bat. I couldn't complain.
It won't increase boost though, but it will increase the power output on whatever boost level u are at.
standard turbo and core should be able to handle up to 13psi if I am not mistaken. If anyone can correct me on that, go ahead.
hope this helps
Pete forget about your ECU at this stage and finish off your exhaust. Going from a 3" Cat-back exhaust to a full (front/dump/cat/back) 3" exhaust I gained 10rwkw.
Then taking the boost from the standard 7psi to 11-12psi is another 10rwkw gain.
yeah what ben said... get a dump and front pipe and a 3" cat (round $700-800 for that lot) and defenately get a new intercooler before even thinking about management, Australia's climates really screw with forced induction without decent cooling... then, with the series 1 turbo, you could wind up to 14psi safely and you'd be looking at around 160ish rwkw with those mods.
Christian
As mentioned above, do the dump and get a front mount and a simple boost controller. And a boost gauge would help too.
The e-01 is a boost controller, not a piggy back, the e-manage is the fuel/ignition computer.
ok thanks guys... i will get hold of the down pipe and front pipe to finish of the exhaust! IF ANY ONE KNOWS OF ANY FOR SALE PLEASE LET ME KNOW!
as far as the front mount goes i am avoiding it simply because of the cost and that i will probbaly have to replace the front bumper for airflow and room! i would think that it would be impossible to fit a gtr core behind the s1 bumper??
Hi Gson,
I get most of my exhaust mods done by Glenroy Exhaust in Campbellfield, recently got my front pipes done for the GTR their. No offence to BATMBL but can't see them doing any better job than the guys at Glenroy Exhaust & Paul always looks after me on price $$ 350 fitted.
Ask for Paul - "if you like" tell him Simon with the GTR sent you
Glenroy Exhaust Centre
12 Dennis St Campbellfield 3061
Tel: (03) 9308 0310
PS: They been in the industry for years, & most of their work is performace stuff. The guys their really know their stuff.
meshmesh
Intercooler wise the trust R-SPL tube and fin core replacement would offer improved performance over stock and fits in the same position for about $900.
The airflow of the original postion is much better than a frount mounting but, has space limits.
See how you go without the intercooler upgrade first.
Totally agreee with benm.
Since you have a 3" cat back system, get one of batmbl's 3" dump/front pipe. It certainly did the trick on mine then get the SAFC to tune the air flow.
the R-SPL is the tube and fin core. The R-spl core is the one you get with the trust intercooler that bolts in the factory position (ie: it's a side mount not a front mount). Front mount intercooler kits are availible in a variety of core spec and sizes.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
